Driver's Side Quad Door Sticking
Old Jul 28, 2006 | 06:16 AM
TopGun's Avatar
I got a problem with the driverside back door sticking to open it I got to push in on it and then it will open up help me please
Thank You
Old Jul 28, 2006 | 08:17 AM
J BODY's Avatar
Remove the two screws in the inside grab handle, remove the one torx behind the door release handle inside and then the panel can be pried away (door panel tool works nice). Most likely you will find the bolt in the center pivot for the handle loose. Tighten that up and the door will work.
Old Jul 28, 2006 | 08:37 AM
smokindog's Avatar
Ahh, I wish mine would even open. After a couple months of head scrathing (obviously it's not that important) I finally investigated. My lower latch spring had broken rendering the door in a constant locked postion even when pulling the handle. I picked up a new latch and it is sitting in it's little box on the back seat waiting for me to replace.
Hopefully your problem is solved by JBODY's recommendation, but if that doesn't do it start looking at the latches, top & bottom, they function very much like the tailgate mechanism and are a piece of cake.
Old Jul 28, 2006 | 09:22 AM
amartinson's Avatar
There are rods that run from the handle to both the upper and lower latches. On mine, one of the rods had slipped on the clip by the handle and I really had to yank the handle to get the door to open. I just removed the door panel and adjusted the rods at the clips by the handle and everything is great again. This may not be your problem, but it is another possibility.
pwregan
14
Sep 18, 2009 07:33 PM
nomad65
Aug 20, 2007 06:01 PM
1stTimeAround
May 25, 2007 03:49 PM
trik396
Aug 19, 2006 01:18 AM
TxDiesel007
Jul 31, 2005 05:59 PM
