Dodge Vs Tree!!!!
Old Mar 26, 2005 | 01:43 AM
Wolff's Avatar
Dodge Vs Tree!!!!
Well, I was backing out of a friend's shop and his dog ran behind me and instead of hitting the brakes I cut the wheel and my drivers side front fender hung a tree. The tree tore the fender up pretty good including the headlight and turn signal. I am going to get an estimate done on it Monday. How much should it run to replace the front left fender and headlight assembly?
Old Mar 26, 2005 | 06:10 AM
mikmaze's Avatar
with paint you are sorry to say going to crack a grand, unless you know a shop and go knockoff parts could get time consuming if the other panels/ hood are out of whac, I'd say he owes you a pup if that dog ever has puppies.
Old Mar 26, 2005 | 10:23 AM
A-Poc's Avatar
so I'm guessin the tree won
Sorry to hear that though... I know the feelin when something like that happens
Old Mar 26, 2005 | 02:32 PM
Wolff's Avatar
I would say the tree won for now... I am going back tonight with my chainsaw I figured it would be close to or over a grand. It only damaged the front left fender and the headlight/turn signal assembly. It did not damage the lights themselves, just the mounting bracket.
Old Mar 27, 2005 | 04:22 AM
Valv's Avatar
Go to CertFit and it will cost you approx $ 150.00 + paint job.
Old Mar 27, 2005 | 07:10 AM
amartinson's Avatar
Just had a fender replaced on one of our 2001's at work. The cost was over $900. They said that most of the labor was that the inner fender is welded onto the outer so they had to drill out the spot welds, remove it, and weld it onto the new outer fender. After you add on any damage to the lights, you should easily go over a grand.
Old Mar 27, 2005 | 08:07 AM
Stamey's Avatar
Maybe, just maybe, you could find a used fender in your color, and just bolt it on. It will probably come with inner fender, etc.
www.car-part.com.
Chris
Old Mar 27, 2005 | 08:54 AM
mini14's Avatar
checkout www.rockauto.com, they list prices for body parts.they have oem and cheaper knockoffs.
Old Mar 27, 2005 | 08:55 AM
mini14's Avatar
www.rockauto.com sorry
Old Mar 27, 2005 | 10:29 PM
farmer dave's Avatar
Have you tried turning it into your auto insuramce, or maybe your buddies homeowner insurance? It would be worth a call or two.
Old Mar 28, 2005 | 07:00 PM
Wolff's Avatar
I got an estimate today... $1395 He is going to try and turn it in on his home owner's insurance. If that does not work then I will turn it in to progressive.
Old Mar 29, 2005 | 12:33 AM
BoostdCTD's Avatar
Time to upgrade to sport headlights? May just as well find the good in the bad.
Old Mar 29, 2005 | 02:57 PM
Korney's Avatar
I just drove my quad off the front of my quad rack and now I have 1 million back windows. I recomend everyone tint theirs so it stays in one piece if this happens to you. It is half as much to put in a slider window so I'm upgrading and that's my good in the bad.
Old Mar 29, 2005 | 04:06 PM
azcwbyteaser's Avatar
ouch sorry to hear that wolff and I feel your pain..sucks when something stupid causes ya to hurt your baby..good luck with filing it under the insurance...if worst comes to worst just say it was parked somewhere <bar or something> you came out n bout died..my bro used that line on his 87 ford diesel when his girl at the time back into it broad side with with a trooper
~Heather~
Old Mar 29, 2005 | 06:10 PM
99 cummins's Avatar
I just replaced the headlight, you can't get just the mounting it's all one piece. I payed $130.00 from Auto Zone and it is a nice replacement that just screws right into place. But after that I found the exect same light listed on ebay for about $35.00, listed the same brand name and everything.
JKM
Mar 22, 2005 10:48 AM
Shaders 24v
Mar 1, 2004 12:16 AM
Crazy Horse
Nov 5, 2002 10:41 PM
