dodge door rust
Old Sep 9, 2007 | 10:38 AM
edy's Avatar
edy
dodge door rust
is there any way a do it yourself diesel mechanic like me could repair the rust on the bottom of my door any suggestions its pretty bad
Old Sep 9, 2007 | 10:54 AM
kawi600's Avatar
I did mine at first by slicing out all the rust and using fiberglass cloth with polyester resin in layers to make a new surface where the rust was. The problem with this method is its messier and requires re-repair of the whole area after a dent/crack. Something I found real useful was using sheet steel and wax paper as a mold to get a nice flat finish.
What I did this time around was to take a cutoff wheel and make some square cuts around the rust. Then get some heavy sheet steel and trim it down to a very good fit in the hole. Then use magnets or vice grips to hold it and tack it on with a MIG welder. Ive had very poor luck doing stitch welding with this. I ended up doing a stitch method but with individual spot welds until they overlapped.
Then all you do is grind the welds flat, fill with bondo, sand with a backing board and paint.
Im using some rust converter I bought from theruststore.com (its the tannic acid type) which works nicely on rust so far. You can also use a zinc-phosphorous solution to etch / rustproof the panels or use some zinc etch primer under a primer-sealer.
One last thing.. Id drill some drainage holes into the area at the bottom of the door sill and door skin so water doesnt collect.
brianpgriset
14
May 21, 2008 11:33 AM
SmokenRam
Oct 30, 2006 11:03 PM
Common
15
Oct 13, 2006 11:09 PM
greasemonki
Dec 9, 2005 09:52 PM
sherod
14
Sep 24, 2004 10:35 PM
