Different VP44's?
Different VP44's?
Is the VP44 for a 245 HP different than one for a 235 HP?
Or rather, in my case, would a 245 VP44 work on my 235 HP
CTD? No problems with mine I can see but I'm saving my pennies to get a spare just in case.
They are somewhat different......The HO VP-44 is designed to flow more fuel. SO's respond better to fuel boxes, while HO's resond better to bigger injectors. Here are the improvements that were made in the ETH engine:
What's new in the ETH engine:
Electronic Controls: New ECM calibration and fueling algorithms.
Fuel Pump: Increased fuel flow in the Bosch VP44 injection pump.
Injectors: Designed to provide increased fuel flow.
Injector note posted to the TDRoundtable by tgbol:
ETH injectors (3946306) flow 600cc at 100bars for 30 seconds
ETC injectors (3944828) flow 640cc at the same test.
Turbocharger: Revised wastegate setting for 26psi at the turbocharger outlet.
Manifold boost specification is 43.5 inches Hg / 21 psi
Head: Valve seat inserts for added durability.
Pistons: New pistons with higher 17:1 compression ratio.
Flywheel: New flywheel with 330 mm diameter clutch (vs. std. 310 mm).
ISB Design Improvements and Features - from 1998 Mastertech
FWIW: Reports from owners indicate that ETC engines are more responsive than ETH engines are to the major fueling boxes.
jhenson
09-08-2012 10:37 PM
Fisherguy
29
08-06-2009 12:45 PM
Dave88LX
12-08-2006 02:53 PM
