Differences?
Old Mar 8, 2008 | 03:51 PM
shorthair's Avatar
Differences?
what are the differences between the 94-98 2500's v 3500's, I know the front hubs & the wheels but are the brakes bigger, are both dana 70 or 80's I think the springs are the same ,right ?
Old Mar 10, 2008 | 09:27 AM
dozer12216's Avatar
Some things will interchange, some may look similiar, but not have the same capacity, and some things just will not work. A salvage yard would be a good place to check on individual parts interchange. Dealer parts books will drive you crazy on supersed numbers.
Old Mar 10, 2008 | 01:46 PM
meangreen96's Avatar
- All Cummins 5spd are Dana 80
- All 3500s are Dana 80
- You could order a camper special package on the 2500 which would net you the auxiliary springs and sway bar ala the 3500. This was their way of having a single wheel 3500.
Old Mar 10, 2008 | 01:57 PM
Purplezr2's Avatar
So my 2500 8800GVW is really a 3500
Old Mar 10, 2008 | 04:47 PM
That's the way it was explained to me. So, that's how I view mine. When I ordered SS brake lines from EGRbrakes, mine fell under the category of 3500 SRW. It just sounds better too.
- Craig
Old Mar 10, 2008 | 05:02 PM
shorthair's Avatar
so if i buy a 94-98 2500 as long as the tires will carry the load it's OK ?
Old Mar 10, 2008 | 05:33 PM
PaulDaisy's Avatar
I don't think so. The rear drum brakes at least are different if my FSM is telling the truth.
Old Mar 10, 2008 | 07:48 PM
What does the manual say about the brakes?
Old Mar 11, 2008 | 12:21 AM
PaulDaisy's Avatar
Front wheel caliper piston diameter:
2500 - 80 mm
3500 - 86 mm
Drum brake dimensions:
2500 - 13x2.5"
3500 - 13x3.5"
Wheel cylinder diameter:
2500 2x4 - 24 mm
2500 4x4 - 27 mm
3500 - 27 mm
Old Mar 11, 2008 | 09:36 AM
Yeah, but you order parts based on GVW. I checked Napa's site. So for a 2500 you have two options:
w/ 8,800 lb. GVW w/ 3.384in. (86mm) Caliper Piston Diameter
w/ 7,500 lb. GVW w/ 3.125in. (80mm) Caliper Piston Diameter
I buy parts to the 8800 GVW. It should be the same for a 1 ton.
GO 4LO
Jun 7, 2003 09:21 PM
j28s
Feb 14, 2003 04:14 PM
boughtadodge
Dec 2, 2002 02:44 PM
joel
Nov 11, 2002 09:14 PM
