day time running lights
DRL disabled
I unpluged the DRL module and everything works except DRL and my high beam indicators. Looking at the wiring diagram, it show the high beam indicator wired to the DRL module for Canadian trucks or directly to the high/low beam selector switch in the cab for U.S. trucks. Does anyone know of the wiring is all ready there to connect the high beam indicator to the high/low selector switch? If it is, where is it located? Thanks.
AlpineRAM posted some good info on the DRL with the pin out for the module so you can jumper the leads. It was cross posted with thread I had on the DRL also as mine was dying. I have mine unplugged and not much luck with the jumper for the High beams..
Same with me.. I couldn't get the hi beam indicator to work either.
My new plan is to cut the sensor wire for the parking brake and ground out the line to the module so that the module thinks the parking brake is on. With the lead to the brake unhooked it shouldn't trip any lites in the cab, everything should work as normal.
Dale_K
33
12-28-2007 09:39 PM
KWKING
10-04-2006 09:40 AM
