Custom Lowering Kit?
Old Aug 4, 2010 | 10:35 PM
mechrisme's Avatar
I have been looking through the 1st and 2nd Gen forums for like over the past week page by page, I'm on page 325 of 426 so far. I ran across someone with a 1st gen that lowered it down by flipping and moving the rear shackle mounts and heating the front coils to lower it down. I have been waiting to like lower my truck down some more and I already have longer shackles. Most lowering kit come with new front shackle mounts but they don't make them as far as I can find for a 8800 GVW truck. I also have read that a couple people have cut the front coils to lower the front end down. Basically I have thought of getting some coils off a 1998 dually and cutting them to see how they fit and also if the rear shackles are the same, modifying them so it would lower my truck down some more in the rear. Anyone have any advice or opinions about my ideas?
Old Aug 5, 2010 | 07:57 AM
high bid's Avatar
will the 1500 springs fit?
Old Aug 5, 2010 | 09:02 AM
mechrisme's Avatar
I did see a truck like mine on craigslist one day and he had lowering spindles and half ton coil springs. I can't seem to find lowering spindles for my year truck and I don't its that great of an idea to put half ton coil springs.
Old Aug 5, 2010 | 09:25 AM
Diesel Dave2's Avatar
Pickin on the wrong admin...
I'm going to try 1500 springs off a dodge 4x4 to lower my front end on my 4x4...So many different ideas....One person says to cut coils,the other says its a bad idea...Seems the same in installing 1500 coils...I'm going to start testing these ideas and see what is the best...For sure lowing spindles are the way to go.....If you could find them..
Old Aug 5, 2010 | 09:26 AM
mechrisme's Avatar
I know 1500 spring aren't the same off a 1998 for sure as my 2001 but I would say it would fit 4wd wise since they use 2500 and 3500 springs to raise theirs up.
Old Aug 5, 2010 | 12:16 PM
BigGreen's Avatar
Look on belltech web site I found allot of different options for dropping our trucks. Remember in the search you might have to use V10 it is the same and the 5.9 24V all part numbers are the same on like trucks. I had remembered as I was going to drop my 96 dually 3500 V10 but sold it instead.
Old Aug 5, 2010 | 03:43 PM
mechrisme's Avatar
I think I have been there before but I just checked and the kits say they fit 94-00, I don't see much difference.
Old Aug 5, 2010 | 06:54 PM
BigGreen's Avatar
Will work the same.
Old Aug 5, 2010 | 11:05 PM
mechrisme's Avatar
I also have ran across that my truck is 8800 GVW so the leaf springs are wider then regular trucks so thats also a problem.
Old Aug 6, 2010 | 04:06 PM
Dan Turner's Avatar
Cutting coil springs will increase the spring rate quite a bit.
Old Aug 6, 2010 | 04:37 PM
Hodge's Avatar
I'm curious- why do you want to lower it?
Old Aug 6, 2010 | 08:37 PM
mechrisme's Avatar
Well I've had it leveled out and it looked good but I like it how it handles at stock, I've had a couple people think my truck was a half ton before. I just would like to lower a little more to reduce the gap in the wheel wells.
Old Aug 6, 2010 | 09:15 PM
bigredBCS's Avatar
i raised the spring hangers on mine about 3 inches. it doesnt look much lower but thats because it has 33" street tires on it
this is the only good picture i have of it
Old Aug 6, 2010 | 09:31 PM
mechrisme's Avatar
how did you rasie them? My brother got a 1998 12 vavle quad cab dually with a 5 speed, we thought of making it a short bed dually or short bed SWD like mine
nasty01cummims
Jun 30, 2009 01:52 PM
4doogie
Feb 5, 2007 08:48 AM
jarmar
Jul 4, 2004 11:51 PM
Pike
Nov 29, 2003 09:14 PM
ET_178z
Jun 11, 2003 02:17 PM
