cruise control
Old May 19, 2006 | 05:18 AM
deezel's Avatar
cruise control
cruise will not come on.indicator comes on when ignition turned on.thanks in advance for any replies.
Old May 19, 2006 | 09:09 AM
CTD NUT's Avatar
Any codes? You might get a 1595.......
Old May 19, 2006 | 10:13 AM
Bobcat698's Avatar
Do your dash vents for the AC/heater work?
Old May 19, 2006 | 10:21 AM
P.J's Avatar
P.J
Sounds like everyone's thinking vaccum problem?
Old May 19, 2006 | 12:11 PM
scuzman00's Avatar
Not to hijack thread, but my cruise control intermittently acts up since I installed my EZ. It sometimes wants to surge up above setpoint and then stumble below setpoint. I am guessing that the EZ's electronics are the culprit. Any suggestions???
TIA
Gary
Old May 19, 2006 | 07:46 PM
infidel's Avatar
Gary , this may sound silly but it works. Remove the vacuum line from the actuator under the battery and stick the extension tube from an aerosol can in the vacuum line. The restriction will slow the cruise down. Only problem is I'm not sure if the '02 still had the vacuum actuated cruise, if so your problem is likely electrical.
Most cruise problems are caused by battery acid corroded wires, hose or actuator under the battery or by a bad brake light switch.
Firstgenfanatic
Nov 8, 2009 04:05 PM
Landini1
Mar 6, 2009 07:01 PM
trophystock
Jul 6, 2006 06:28 PM
sam
Mar 31, 2003 09:04 PM
TexasDiesel
Dec 27, 2002 10:47 AM
