Color wire for backup lights?
Old Dec 28, 2006 | 10:12 PM
ajg617's Avatar
Does anyone know the color of the hot wire to the backup lights in the harness out of the steering column? I want to add some halogen backup lights and need to tap into that wire. 2001 quad cab
Thanks,
Ajg
Old Dec 28, 2006 | 10:23 PM
BIGROD's Avatar
I just tapped the hot wire at the bulb. Mounted a relay on the frame and ran a fused hot wire from the battery to the relay.
This was the easiest was I could see to do this. I used the cheap off road light relay.
Hope this helps Rodney
Old Dec 29, 2006 | 07:07 AM
93w250's Avatar
If you have the rv connector just tap into that. That's how I did mine. I also use a relay. The back up wire in the trailer connector powers the relay, and the power for the lights comes from the aux wire from the trailer connector. Works great.
Old Dec 29, 2006 | 08:06 AM
CRSmith's Avatar
I found a bolt that fit in the center terminal of the 7pin connector, which is the reverse circuit for a trailer. I wired to the bolt, and stuck the bolt in the terminal with a little dielectric grease. This saved me from having to splice wires. I have to unplug the backup lights when I tow, but it is not that often. Then of course, I had to ground the lights to something.
Old Dec 29, 2006 | 06:16 PM
TIMMY22's Avatar
I did the same thing, I bolted the black rubber coated napa lights to the holes in my pintal plate. then, wired up a trailer connector plug just using the center pin. works great.
Old Dec 30, 2006 | 08:54 PM
ajg617's Avatar
Thank all
What a clean solution. Thanks folks.
AJG
robert78.5
Jan 20, 2008 10:18 PM
Syndicate
13
Oct 8, 2006 10:30 PM
mt72916
Feb 1, 2005 08:00 AM
99DodgeGuy
Dec 18, 2004 10:08 AM
TPilaske
16
Nov 22, 2002 08:15 PM
