Co-Pilot Door Loose
Old Feb 28, 2012 | 07:51 PM
Kidrod's Avatar
Co-Pilot Door Loose
Hey Guy's, my 95 2500 passenger door makes a clunk noise when it hits a bump once in awhile and with a good head wind I can air leaking past the seals, never seems to leak water though. I've looked in the service manual but can't seem to find any info. How do I adjust the door to make it suck in tighter to the cab? I have checked for excessive play in the upper and lower hinges but they are tight. Thanks Tim
Old Mar 1, 2012 | 08:23 PM
Kidrod's Avatar
Nobody knows? Or is my rig the only one that does this? Thanks again.
Old Mar 2, 2012 | 12:00 PM
Busboy's Avatar
Could be no one knows what a "Co-pilot" is, it's been FO's for a very long time.. Anyway.. roll down your window and open the door. Sit on the seat facing the door, take hold of the door frame at the top put your foot against the door at the bottom of the opening then pull in on the door frame bending the door frame inwards a little.
Old Mar 2, 2012 | 08:52 PM
Kidrod's Avatar
Ya Gotta be kidding me, this is the help you wanna give someone? You actually want me to bend the window frame like an ape trying to get out of the cage? I think I'll try adjusting it in a more delicate manner, thanks for the intelligent reply.
Old Mar 2, 2012 | 09:18 PM
Busboy's Avatar
Believe it or not that's the way it's done, I wouldn't feed you a line.
Old Mar 3, 2012 | 01:21 AM
nickg's Avatar
agreed, usual method of tightening door seal, especially if hinges are tight, you dont need to bend the window frame, just tweek it a little
if you monkey around with the hinges alignment you will more than likely make it worse, and have a door that does not shut well.
Old Mar 3, 2012 | 09:18 AM
gorms's Avatar
If the door lines up with the body lines good and the door closes without hitting (check around the striker for signs of the door sagging) then I wouldn't adjust it. If not, you can adjust it by loosening the bolts on the door side slightly, I like to leave the bottom most bolt tight, helps keep from over-adjusting. Mark where it was with a pencil and go in small increments if you need to. Also check the weather stripping to see if any of it is collapsed/folded over. Good luck.
Old Mar 3, 2012 | 11:32 AM
SIXSLUG's Avatar
You gotta remember its a Dodge.
Passenger side hinges don't usually drop, unless its a work truck and got a lot of use.
The standard way of fixing the misalignment is to "tweak" the window pillar in as described. It'll go a little better if you support the door at the bottom with some cribbing so you aren't fighting the suspension.
If you search something like "door seal leaking" you will find the same advice with many positive results and grateful comments.
Old Mar 3, 2012 | 09:52 PM
Kidrod's Avatar
Thanks Guys, Sorry for the negative reply to "Busboy" I've been a member of a motorcycle forum much like this for a long time....sometimes over there when a newbie asks a question he gets a stupid reply from some idiot that's had too many beers. The door hinges are fine and the door does not sag at all, it simply won't suck up to the cab like the driver door does. I can push on it from the outside and see this. I'll look in my manuals again. Have a good weekend Tim
Old Mar 4, 2012 | 11:42 AM
SIXSLUG's Avatar
I understand, Kidrod.
This forum has a lot of great guys that want to help and the moderators are pretty good at keeping house.
Good luck on fixing your leak!
kurt
Old Mar 4, 2012 | 12:10 PM
torquefan's Avatar
The striker is adjustable, and sometimes moving it in a bit is all that's required to pull the door into the body a bit tighter. If you go too far though, the door, when closed, will have the rear edge below flush with the body.
I have also adjusted many doors by pulling in the top of the window frame like was explained above. It can help a lot with wind noise, and I believe it to be an acceptable repair.
Have a good look at the way the door sits now, hopefully you can see where it doesn't fit the body tightly, and can decide on where it leaks and where to adjust it. To see if the weatherstrip is compressing properly, shut a five dollar bill in the door, in different locations, then pull it out. You should feel decent drag on it with the door closed. If there's a spot where it'll pull out with no drag, that may be a leak spot.
Old Mar 4, 2012 | 01:22 PM
Busboy's Avatar
Thanks Guys, Sorry for the negative reply to "Busboy" Have a good weekend Tim
No problem I have very sloped shoulders and stuff just runs off. As has been mentioned by some of the other posters because it's the passenger door it's unlikely to have worn out the hinge and if the door fits flush with the body when closed and the seal is in good shape, it is usually the window frame that needs a tweak. It could have got out of position by something as simple as someone using the door frame to get into the truck or perhaps an accident or even just the repeated slamming of the door over time.
Old Mar 4, 2012 | 05:45 PM
Kidrod's Avatar
Thanks but a FIVE dollar bill? I'm a starving airplane mechanic in Kalifornia!
Will a ONE work?
Old Mar 4, 2012 | 05:49 PM
Tallguy67's Avatar
Kidrod - like me, torque fan is from Canada. We don't have bills smaller than $5 up here.
Old Mar 5, 2012 | 07:49 PM
Kidrod's Avatar
Just makin a joke about being poor, I didn't know that about the money. Hell a one dollar bill in Kalifornia might as well be toilet paper as it can't buy a single roll
