Check out my new rig.............
Old May 23, 2006 | 06:44 PM
Iwantadodge's Avatar
Hey guys! I am a Newbie. Here she is...... 01 2500. H.O. diesel, 6-speed, SB, 106K. Laramie Package. Just about every option you can think of. Very well kept. One owner. Was kept in a heated garage. No rust underneath due to the epoxy put underneath of it. Never pulled anything. All stock. $19,500 is what I am giving for it. Sound like a pretty good deal? Going up this weekend to get it. Well?? Opinions? Things I should do to it when I get it? Thanks! Paul
Old May 23, 2006 | 06:46 PM
G1625S's Avatar
Fuel pressure and pyro gauges and BOMBs away! Sweet rig. I'd be proud to call it mine own
Old May 23, 2006 | 09:14 PM
ANG012's Avatar
Check for the 53 block and for water leaks on the pass. side of engine below the freeze plugs.
Old May 23, 2006 | 10:16 PM
3500Dooly's Avatar
nice rig dude!..... love the 6! its the best!
Old May 24, 2006 | 06:46 AM
Joe Diesel's Avatar
yup what G1625S said ...gauges 1st
Old May 24, 2006 | 07:42 AM
Dshiftff's Avatar
6sp defenetly a good move. Sweet rig good luck
Old May 24, 2006 | 08:56 AM
TxDiesel007's Avatar
What he said...
congrats on the find, good luck and hope she treats u right...
Rick
Old May 24, 2006 | 04:11 PM
98silver12v's Avatar
Talking
Nice find looks very clean. let the bombing begin.
Old May 24, 2006 | 09:09 PM
1qckdodge's Avatar
That looks real niiiiice
Old May 24, 2006 | 09:23 PM
hotdram's Avatar
It's the right color too
~Rob
Old May 24, 2006 | 09:44 PM
Dieseldude4x4's Avatar
~Rob
YEP, what he said.
Old May 25, 2006 | 07:25 AM
Pooter's Avatar
**** good looking truck...
Wish I had it(or one like it)
Old May 25, 2006 | 08:36 AM
Clunk's Avatar
Thumbs up
Welcome and congrats on a good looking truck,
Your Dodge/Cummins has fuel milage and power capabilities far beyond a basic gasser but it isn't gas-n-go like a gasser either...it's a bit involved but not difficult to manage.
Obtain a repair manual at your favorite auto parts store so you can get up quick on your truck. You also need gauges to get info from your truck but more on that later..
Your 24 valver has a Lift Pump that takes fuel from the fuel tank and delivers it to your Injector Pump(VP44). This VP44 is the weak link and because it's so expensive, it deserves extra consideration. For years the guys here have been trying different things to get the VP44 to live and through basic R&D, they've discovered a few things that help most and are running up the miles.
Fuel lubes and cools the VP44 and we watch that with the Lift Pump fuel pressure. We generally like to see 13-15psi idle, 12-13psi cruising hwy speed and no less the 5-7 psi at wide open throttle(WOT) stock.
A fuel pressure test gauge available at your favorite auto parts store, connected by pressure line to the Schrader Valve on your injector pump and installed in the cabwill get you lift pump fuel pressure to watch. Check my picture gallery.
Diesel fuel has very little if any lubricating abilities so fuel treatments like Power Service, Howes, Lucas and Stanadyne add lubrication to the fuel. I use the MFG's recommend on dosages.
There is fuel returned to the fuel tank from the fuel system and because some of it comes from a passage in the cylinder head of the motor, it's hot. This is fine in the winter because diesel fuel can gel in very cold temperatures BUT in the summer, it can get hot enough that it won't cool electrical components in the VP44. Most folks are keeping their fuel tank 1/2 full or better. We're currently looking for an end all fuel cooler that does not restrict flow or pressure.
Many folks have found that they had no lift pump pressure after they install a gauge or change the fuel filter so be ready for that.
Type "lift pump" in the search box for lots of info.
westcoaster
May 5, 2007 10:15 AM
hilclmr
14
Aug 30, 2004 11:43 PM
jaconst
May 19, 2004 04:14 PM
wooff
Apr 27, 2003 10:23 PM
FireNhole
Jan 28, 2003 06:13 PM
