A/C Help - Experts Inside Please
Old Jul 15, 2008 | 11:42 AM
xtoyz17's Avatar
Blend door or plugged evap. Search my name and dash, I gave a pretty quick run down a month or so back about how to get the dash out.
You have two options to getting the vent box out. Unbolt, swing dash up and drop it out or my personal favorite is pull the entire dash off and set it on the seats so that you have the whole firewall open and easily accessible.
Old Jul 15, 2008 | 09:56 PM
EverydayDiesel's Avatar
I took the dash out and got the evap core out.
The evap core was plugged. I needed to replace heat exchanger anyways since it was leaking.
Old Jul 15, 2008 | 11:24 PM
Diesel Doc's Avatar
glad you found the problem
Old Jul 16, 2008 | 11:16 AM
No im glad you found the problem.
Thanks everyone for the help!
Old Jul 16, 2008 | 11:20 AM
Now do I have to clean the lines out?
What about oil? Do I have to add any pag oil?
Old Jul 16, 2008 | 12:12 PM
Diesel Doc's Avatar
if you didn't lose much when you drained it it should be ok the lines should be fine also
Old Jul 17, 2008 | 12:41 AM
What caused my evap to plug? Everything was new around it...it doesnt make sense.
How do i know how much oil i lost in the lines? its plugged and nothing is draining out.
Old Jul 19, 2008 | 05:07 AM
khrad's Avatar
actually,I now this might be a little late, but there are 3 little screws that hold your blower motor and fan housing in place ,if u drop same u can access the evap for cleaning and inspection. if you have to remove the evap ,were talking the whole dash
Old Jul 19, 2008 | 04:32 PM
thanks thats a good tip for someone in the future. I had to remove the whole freaking dash. It wasnt that difficult but it was time consuming.
Old Jul 19, 2008 | 09:31 PM
jrs_dodge_diesel's Avatar
Incoming air that goes to the evap (whether it fresh air or recirculated air) is not filtered when it passes through the evap. Now when your A/C is running the evaporator will condense any water vapor in the air, which collects on the evap tubes, and normally drains off. This means the evap lines are usually moist when the A/C is running. Now, combine a moist surface and unfiltered air, and you have a dirt magnet. Then what happens is that when the A/C is shut off the lines dry off, but the dirt/dust is left behind, and starts building up as the A/C is used and turned off. It eventually clogs as you had found out.
Hope this explains it.
EverydayDiesel
48
May 26, 2008 11:47 PM
DodgeDemon
Jun 30, 2007 01:44 PM
Atlantic4x4
Jun 8, 2007 03:14 PM
cumminsman02
Oct 11, 2004 05:09 PM
1320
Sep 10, 2004 09:04 AM
