a/c help
Old Jul 16, 2012 | 10:26 PM
maroonbeast01's Avatar
a/c help
For awhile now i have had a small slow leak,well now my compressor is starting to lock up so i havnt used my a/c since april. I am going to replace the compressor and all the small o rings and the actuator canister. What else should i replace while i have the mess made? I have seen many people talk about the evap core going bad....? I want it to be like alaska in the cab again not a sauna!
2001 ext cab 4x4
Old Jul 16, 2012 | 10:57 PM
roughstock's Avatar
I would remove compressor, dryer, and orifice tube. Flush system with AC flush. The reassemble all pieces with new AC o rings. Then if u have access to a tank of nitrogen and regulator. Pressurize the system thru the hi side to about 150psi. Then shut off tank. Pressure should stay. If it drops, u still have a leak. Spray junctions and rubber portions of hoses with soapy water. Look die bubbles. Hope that helps
Old Jul 17, 2012 | 02:21 PM
Sea:\>Drive's Avatar
With a 2001 your evap core may go any day so it is up to you whether you want to replace. Not difficult but time consuming - read the FSM and posts on this site for guidance - just undoing a lot of screws.
2 years ago I did everything except condensor and compressor - this year I have a slow leak so once it gets larger the condensor and compressor are next.
kcredneck
Jul 25, 2007 10:11 PM
ollie32
Jun 6, 2007 09:21 AM
2500TurboDodge
Jul 31, 2006 04:21 PM
bkay
Nov 6, 2003 10:39 PM
