A/C compressor always clicking?
Old May 14, 2009 | 09:58 PM
oww's Avatar
oww
I had my system charged recently and the a/c works great, nice and cold. However, I've noticed that when I don't have the a/c selected, I can still hear the compressor clicking in/out. Is this normal? It seems to me that the compressor shouldn't be working if I don't have the a/c selected. Is there a switch somewhere that has failed? I just put a used compressor in 'cause the system leaked before and the mechanic said the compressor was leaking. (Plus a new dryer because I didn't use the a/c all winter. )
Maybe I need to clean the radiator fins? Just been reading other posts for ideas and I would like some suggestions please.
Old May 14, 2009 | 10:06 PM
Swarthy Dago's Avatar
yes that is not normal, mine won't even click in and out now. if they changed the dryer start there, the switch on top might be bad and won't open.
Old May 15, 2009 | 05:53 AM
JohnBer's Avatar
mine cycles in and out a little on defrost it uses the ac to dehumidify
Old May 15, 2009 | 08:04 AM
Shovelhead's Avatar
Administrator / Scooter Bum
The Face Only position is "vent" and the only position that doesn't cycle the AC compressor.
It's a good thing to have it cycle as it keeps the system seals from drying out.
Old May 15, 2009 | 09:03 AM
infidel's Avatar
This is correct only on '98 and newer trucks.
On the older trucks defrost is the only position that runs the A/C unless you are on the A/C side of the fan switch.
Both "problems" are easy to fix Disable Automatic AC
Old Jun 1, 2009 | 01:33 PM
oww's Avatar
oww
Sorry for the time its taken to respond. I bought an owners manual from Ebay, lo and behold the a/c is often on. Thanks to all for the responses.
WhoCares79
Jun 3, 2008 11:45 AM
Camarogenius
Jun 25, 2007 08:55 PM
JKM
Mar 8, 2006 03:23 AM
Chewy
Dec 18, 2002 06:46 PM
