A/C Compressor
A/C Compressor
I drove to work the other day and shut my rig off, when I did so I heard a metal on concrete noise...well when I investigated I found a round ring off of the front of my a/c compressor clutch had fell off. It had been making some weird noises when I tried to cycle the a/c on the previous day. It looks like I am just going to replace the whole compressor/clutch. My question is, are all a/c compressors created equal? I found some places online that have a new compressor/dryer for around 325 bucks. The dealership wants about 500 bucks and Autozone wants around 400 for the compressor alone. Any places online that you guys have dealt with before?
I got a compressor for my rig on ebay for like 160.00 shipped to my door. I'm getting the system charged this week with a new dryer.
http://stores.shop.ebay.com/TechChoi...__W0QQ_armrsZ1
That looks like a good deal, I only wonder about the quality. I really don't know if there is just one major manufacturer of a/c compressors and everyone stamps their names on them or how that works.
You don't have to replace the entire compressor assy., only the clutch, about $127.00 list at the dealer, worst case scenario.
You actually only need the front clutch cover from the assy., as long as your bearing didn't fail, which you could probably find used even.
Its usually only the spring steel tabs that wear out on the cover where they are attached.
That is possible but if your clutch failed due to rust and corrosion like mine... which it sounds like it did... It can be a PITA to get the old one off.. It was a PITA just to get my old compressor out.. ALL bolts broke off with the bolt still through the compressor so it couldn't drop down, I had to use a HARD CORE air hammer to literally bust the compressor off the remainder of the bolts...
Good Luck !
Are the compressors off the gassers compatible with the ones on the diesels? They look very close to the same unit. If not is it the same from the pulley forward? Thats what was making the noise on mine and then the piece hanging off of the pulley fell off.
The compressors are NOT the same gas to diesel, the mounting holes are totally different and there is no way to use a gas compressor. The other thing the diesel revs much slower so I would think the clutch pulley would be a different size. Just guessing on that one as I have never measured it.
Rockauto.com has compressors staring less than $200.
I'm in the same situation. What needs to be replaced when opening up the A/C system for a compressor replacement? Dryer? Orifice tube?
Dave
Dave
Yes, suppose to change the dryer and tube when you change the compressor. I didn't know this when I did mine and only changed the comp. Had the system charged the other day. I didn't have any issues and it's blowin' icy cold!
Wherever you get the comp. from, Make sure it has the oil in it. Some come with and some come without. The one I got from Tech Choice auto parts came with the oil ready to go.
I'd also go with just replacing the clutch. If it is a pain to get the thing apart, they make an A/C puller/installer. Possibly could rent from an auto store. And yeah they do reccommend replacing the dryer (if ya end up doin a whole compressor), but we've done a few @ work w/o dryers, and havent had any problems. And I would use plenty of anti-seize on the entire length of the mounting bolts in case ya ever have to take the thing off again, they love to seize up in the compressor like someone else already mentioned. And with your truck being a lil bit older, it probably wouldnt hurt to flush the system while ya got it apart. That way, also, you dont have to worry about having too much oil in the system when ya install the new compressor if it comes oiled.
If ya dont wanna buy guages and stuff, do the compressor yourself and take it somewhere just to have it charged, that'd save ya some $$$
