Burnout problem
Old Jul 19, 2006 | 11:16 AM
skargo's Avatar
Burnout problem
I did a burnout in front of my shop yesterday, and it stalled out. It acted like when you change the fuel filter, and it takes awhile to start.
Did I starve it for fuel somehow?
Old Jul 19, 2006 | 12:10 PM
Tiny's Avatar
I had the same thing happen a few weeks ago, during a burnout I had to get out of the throttle suddenly to avoid hitting a car that turned in front of me. Truck stalled out, right in the middle of an intersection after a good smoky burnout. Jumping off the HRVP44 can cause it to stumble, and possibly stall. Only happend the one time.
Old Jul 19, 2006 | 12:55 PM
getblown5.9's Avatar
ive had this happen alot when going WOT and had lots of fuel flowing thru the VP44 and it gets hot...well when you let off the throttle/stop the pump abruptly it can cause the fuel that is trapped within the heayed up VP44 at that point to quickly vaporize and vaporlock the injector lines.
ive done this many times, down to a science now of jumping out, cracking 3 injector lines, turn it over a few times, then tighten the lines up and start the truck. the first couple of times i thought it was the truck running out of fuel, so i kept a an extra gallon in the toolbox. then i realized what was going on and now i jsut keep my wrench handy
Old Jul 20, 2006 | 06:16 PM
skargo's Avatar
Would replacing my FASS 95gph with a 150gph help this? Is any potential damage being done to the stock VP44? Would a hot rod pump take care of this "issue?"
Old Jul 21, 2006 | 09:23 AM
Tiny's Avatar
I have not had to crack any injector lines, and it fires right back up. Mine has the HR pump already, so that is not the answer. I do not have the FASS, so no answer there. Sorry.
Old Jul 21, 2006 | 11:42 AM
skargo's Avatar
I didn't have to crack the lines either.
Old Jul 30, 2006 | 11:31 PM
01smoker's Avatar
Mine would do that too back before I put my FASS on. I would race somebody and I would let off abruptly and it would die. I would then have to coast it off the road. It wouldn't fire back up immediately, but after a few lift pump cycles it would hit and miss and finally smooth out and run fine. I ain't had that problem anymore since I installed the FASS 150.
Old Jul 31, 2006 | 09:21 AM
TravisG's Avatar
What you guyz speak of is called "vapor locked" I dont think going to a bigger pump will help. Sometimes when it happens you will have to crack a line to get her going again.
Old Jul 31, 2006 | 10:03 AM
zukgod1's Avatar
Sounds like most of these guys dont have to crack open thier lines.
dan
Old Jul 31, 2006 | 11:40 AM
skargo's Avatar
Maybe I need to upgrade to the 150 Fass.
Old Jul 31, 2006 | 01:29 PM
Diesel-Dan's Avatar
No you dont.....there is not one VP-44 on the planet that can run away from the 95 GPH. That is not your issue....BUT might check your Fuel Pressure when it dies. See if it fluctuates...if it does...might have intank restrictions that need to be addressed. I have seen VP-44's die like this as well...
kyle_truck_pull
31
Apr 13, 2008 05:28 PM
mr T
Mar 14, 2004 02:05 PM
dodgeram
Mar 9, 2004 12:48 PM
Shovelhead
Sep 19, 2003 08:52 AM
