bubbling/gurgling water sound in dash when first started?
Old Sep 4, 2005 | 10:06 AM
95black2615's Avatar
This happens when I first start the truck in the mornings and only last a few seconds.
Is the heater core clogged or air trapped somewhere?
Old Sep 4, 2005 | 10:45 AM
Catawba Scott's Avatar
My 2001 1500 did that. It was due to a low level of antifreeze. The reason for a low level of antifreeze was a leaking water pump bypass hose. The truck has a 318 V8.
Old Sep 5, 2005 | 09:09 AM
Mopar1973man's Avatar
Total normal.. My mom's 96 does every morning... There is a restrictor in the heater that causes it to gurggle at start up. One of the guru can lead you to the TSB for it...
Old Sep 6, 2005 | 07:08 PM
SmokeyBear's Avatar
i'm interested in the TSB for this one also. mine does the same thing every morning.
Old Sep 6, 2005 | 10:44 PM
ccmckee's Avatar
Mine did it once and the coolant level was low. Topped up the rad and the bottle and it went away.
Old Sep 7, 2005 | 08:09 AM
kd460's Avatar
Totally normal. May even notice it more when the block heater gets used. Kevin
Old Sep 8, 2005 | 07:18 AM
Cool
Ok guys I found the TSB for you...
http://dodgeram.info/tsb/1999/09-04-99.htm
Txwelder
22
Aug 24, 2009 12:51 AM
BART62
Oct 29, 2007 06:11 PM
royta
Aug 4, 2007 02:48 PM
Maverick2001
Jun 4, 2006 10:23 PM
psajb
Sep 24, 2004 10:25 AM
