Brakes and Steering Acting Strange
Old Feb 23, 2016 | 09:52 AM
flyingd's Avatar
Last year I changed my power steering fluid to a synthetic and has worked well. But now every time I turn the wheel it hums and vibrates, Also it hums when I push on the brakes. Also, when I hit the brakes the pedal thumps back at me just for a second. If I hold the brake down it does not keep going to the floor, so that is good. I am afraid it is the power steering pump. Tell me I am wrong.
Any help is appreciated.
Old Feb 23, 2016 | 11:20 AM
gorms's Avatar
Check fluid level hot right after shutdown, should be very little foam if any. If its low or foamy may need fresh fluid. I had the same symptoms in the cold snap we had a few weeks ago, turned out to just be very low on fluid.
Old Feb 23, 2016 | 12:10 PM
flyingd's Avatar
I'll check it when I get home tonight .... thanks
Old Feb 24, 2016 | 09:41 AM
flyingd's Avatar
It was low when I checked it last night......don't know where it all went. Will have to look into that I guess. It still hums very faintly still. If there are no visible leaks do you have an idea where the fluid went?
Thanks
jpz67
May 28, 2007 12:42 AM
Dodgezilla
18
Aug 3, 2006 03:50 PM
03DodgeHO
Dec 28, 2005 11:01 AM
I SPEED
Jan 16, 2005 04:45 AM
Shaders 24v
May 18, 2004 09:07 PM
