Brakes break the bank!
Hi everybody,
I wondering if a few of you could please chime in with your experiences with front brakes. I'm working on the brakes of the truck in my sig (97, 4x4) and I have a persistent problem with a sticking caliper on the passenger side.
I have replaced the brake hoses on both driver & passenger side as I feared they were starting to fail and acting like check valves... No change in caliper sticking problem.
I have used silicone based grease to grease up the caliper pins, and I have cleaned up the rubber boots that the caliper pins are housed in, but I'm wondering if I should replace the rubber caliper pin boots and the caliper pins, perhaps San Felipe Bob can chime in here? Heh heh heh.
I 'm trying to avoid replacing the caliper because I'm cheap (and broke). I have cycled the piston in the caliper in and out, and it appears to be working fine (i.e. it's not cocked or rusted shut, or warped)
Pad wear is looking even on the passenger side, however on the driver side the outboard pad is wearing preferentially.
I just want the passenger front wheel to spin freely... while having brakes at the same time.
Thanks,
Sean.
Thanks,
Sean.
Taxes
I see you're in Canada so I know this price won't pertain after the Queen gets her share,but I bought semi-loaded calipers(you retain your pads) from Kragen for $43.99 U.S. They are Raybestos P.G. Excellent quality and cured my pulling problem.
only one good fix for a sticking caliper, that is to replace it, i have seen sticking calipers get the fluid so hot that the brakes actually faded and could not stop the truck. don't take shortcuts with your brakes, too many lives depend on it.
I agree, NEVER skimp on brakes!
J Lent
Oct 7, 2009 06:50 PM
Chip
14
Jun 21, 2009 03:59 AM
Red3quarter
Sep 6, 2008 11:56 PM
