Brake lights stuck on
Old Jan 24, 2005 | 08:16 PM
RoostrRiz's Avatar
I tried to search this but came up with a partial answer. I have had the infamous ABS/Brake light idicators come on and off intermitently over the past few days. I realize it is probably the sensor in the rear. My more troubling problem is that tonight after getting home my brake lights stayed on after I turned off and left the truck. Also I noticed that the passenger side turn signal would not flash it would just come on solid. Drivers side works fine though. Do you guys think this is a ground problem or something else?
Thanks
Old Jan 25, 2005 | 03:17 PM
RoostrRiz's Avatar
After messing with it today it seems obvious that the previous owner did a hack job on adding a trailer brake controller and just wrapped some of his connections with electrical tape while others were exposed. I pulled the trailer fuse out of the relay box and everything is working normally. I guess I'll be doing some rewiring this weeekend.
polaris800sp
Nov 13, 2008 05:35 PM
Baja
Jan 29, 2008 08:17 PM
CAR Hauler
May 30, 2006 10:42 PM
