Brake Bleeding Sequence
What's the proper sequence for bleeding brakes?
I replaced front pads (hawk), rotors, and calipers. When I replaced the calipers, I did a quick swap from old to new. I did not loose too much fluid from the reservoir. I wanted to make sure I had no air, so I bled all wheels in this sequence:
Rear passenger
Rear driver
Front passenger
Front driver
During the bleed process I noticed the following:
Rear passenger - no air
Rear driver - 10-15 pumps to remove all air
Front passenger - 50+ pumps to remove all air
Front driver - 3 pumps to remove all air
My pedal now feels stiff, but does not seem like the truck is stopping like it should. I want to re-bleed to make sure I removed all of the air, but wanted to make sure I'm bleeing in the correct sequence.
Rear passenger
Rear driver
Front passenger
Front driver
Rear passenger
Rear driver
Front passenger
Front driver
Rear passenger
Rear driver
Front passenger
Front driver
One note, make sure you are bleeding the brakes on a FLAT surface, or with the rear tires slightly more elevated than the front.
It is the correct sequence, longest leg to shortest leg.
Now that I have the front tires back on and you say I have the correct sequence, I'll re-bleed and see what happens.
I don't know if this would apply to your truck, since I'm assuming it's the 2001.5 you have listed in you sig, but I'll throw it out there anyways. First off, my truck is a '97 with 4 wheel abs. When I was tracking down a brake problem I recently had, I came across a different sequence that was based on whether you have rear wheel abs or 4-wheel abs. I always thought, and have done, the sequence you mentioned. But, the shop manual for my truck, which covers '94 to '98 Rams, states the sequence you mentioned is used for bleeding trucks equiped with rear wheel abs only. It further states the sequence for bleeding 4 wheel abs is different...do the drivers side rear first followed by the passenger side rear. The fronts are done normally. It does not state why. The manual lists the whole sequence from the master cylinder on for both types of abs, but, is presented that way in case you had to replace brake lines causing you to have to bleed the the system starting at the master cylinder or starting from any part in between depending on where you had to replace a line. I'm curious if this difference between sequences is something that was carried on after '98?
I have always done furthest from the Master first. (rear pass, rear driver, front pass, front driver.)
There may be different ways.... I would ask the dealer to give you a printout of the maintance procedure... they may work with you.
Did you use "factory" pads and de-glaze the rotors? If the ones in there were factory and you installed different ones then the brakes will feel different.
Hercules, I read my haynes last night and discovered the same thing that you described. But mine says for 4 wheel ABS, to follow the sequence - driver rear, pass rear, driver front, pass front. Maybe that's why it took 50+ pumps on the pass front and only 3 pumps on the driver front.
I know this may sound stupid, but I gotta ask, did you have the brake fluid dumping into a can of clean brake fluid, so when it pumped air out of the brake lines, it would suck fluid back it? Again, not trying to insult anyone's intelligence, but some people don't know.....
Have they gotten better as they've broken in? Can you look up the specs on the hawk pads? Some performance pads are designed to work in certain temperature ranges and while cold they will perform VERY poorly.
The best investment I ever made for this issue, was the purchase of a Power Brake Bleeder, such as those sold through Motiveproducts.com. It easy and eliminates all the problems associated with bleeding
I have been working on my own cars/trucks for more years than I want to admit and I just found out about gravity bleeding. Did it on mine last brake job and fluid flush. You can just let one self bleed whale you are working on another one. Best bleed job that I have ever gotten.
Floyd
Floyd
Dan_K
May 20, 2005 06:45 PM
