Best Replacement Dashboard
I was curious from the many people that have had to replace their dashboards due to cracking what they would recommend. I have seen many LMC truck parts, was just curious if people were satisifed with them, or have had better luck somewhere else. Thanks!
John
John
Plastic Parts, Inc. in Florida makes one. I have not used it yet, but it's on my list. I do not know for certain, but that may be the one Genos sells. I'm sure there are not many companies making an actual replacement dashps/top.
I just need to replace the piece from the bezel around the gauges to the windshield, that's the only one that has two cracks. I like the Dash from LMC and the other piece that you can get with it that spreads the tension to a greater surface area. I just hope it is as thicker and better quality than original. Considering my truck never stays outside, I am very dissappointed to say the least with the dashboard.
I have the LMC cover and it has worked fine; actual dash looked like a huge PITA to replace. My instrument bezel has a crack in it, but I added some glue to keep it tight and has worked out fine.
Put a Dodge replacement in mine a couple years ago - since I was doing A/C and heater core at the same time dash had to come loose either way. Only a day's work w/two guys - wasn't too bad. I do keep the replacement covered though - hoping to get more years than the original (which lasted 8 years).
LMC is OK by me.
Good price, fast shipping and a direct fit. The color was a minor shade off but that could have been my ordering a dark grey and needing a light grey.
The only suprise in my install was that the plastic pieces(go figure) that pop into the firewall and you screw the dash into were broken also. I ended up fabbing some replacements out of a hunk of HDPE I had been using as a cutting board.
Don't use armor all= No cracked dash. All mine are perfect. They stay that way in the Georgia sun too. I leave em dusty and they're perfect. Both 97's and now an '02 and '03. Past armor all use by a p.o. or dealer spells death down the road for your dash
cumminsho2500
28
Nov 4, 2003 09:17 PM
