axle runaway
Old Jun 13, 2006 | 08:31 PM
bek's Avatar
bek
axle runaway
We threw a rear axle today. The little clip broke up and the axle nut spun off. Luckily I was only going 20 mph. The axle came out about 2 feet. Does anybody know how far you can bend these before they're trash. Whats the runout. Thnx Steve
Old Jun 14, 2006 | 03:23 PM
Fugly YJ's Avatar
If it's bent I wouldn't run it at all. That would probably pretty tough on the gears/carrier. I dunno...
Old Jun 15, 2006 | 11:51 PM
8lugXJ's Avatar
Exactly. Bent at all = no good. You will have minor vibrations or even major ones and you will see bad tire wear.
Old Jun 16, 2006 | 07:30 AM
JD730's Avatar
I don't think you would see bad tire wear with a full floating rear. It would however be real hard on all the bearings/parts in the hub/spindle area and the carrier/side gear area. If you could even get the bent axle to go back in.
Old Jun 23, 2006 | 04:51 AM
ProspectorTim's Avatar
By all means, replace the axel to prevent serious ear damage caused by the whining noise coming from the passenger seat when your wife/girlfriend has to endure the shaking caused by the bent axel!
Dan_K
27
Apr 13, 2006 09:23 PM
G1625S
Feb 16, 2005 07:09 PM
dzpoorjr
Jan 22, 2005 10:29 PM
Berak
Feb 27, 2003 06:23 PM
