axle ratio???
Old Nov 16, 2007 | 09:39 PM
rolling18's Avatar
axle ratio???
heya guys after much searching i am unable to find the axle ration of my truck...
it wasnt on the metal ID plate by the radiator
not on the sticker under the hood
no sticker in glove box anywhere
not in the VIN code
no axle tag on the differential itself
there are a few sets of numbers on the back of the diff cover, but none showing a ratio.
am i missing anyplace?
thanks
(i dont want to go to dlr to get build sheet if i dont have too)
Old Nov 16, 2007 | 10:53 PM
oldblues's Avatar
hi
go to local dealer and give him the serial no and they will print you a 3 page build sheet with every option on your truck !
Old Nov 16, 2007 | 11:22 PM
displacedtexan's Avatar
Sounds like it's either the dealer, or counting teeth on the gears...
Old Nov 17, 2007 | 12:38 AM
DL1221's Avatar
On my '96 its on the sticker on the front of the hood. Anyway, it should be either 3.54 or 4.10. Assuming you have stock size tires, get on the highway and go about 70-75 MPH, if the engine is spinning at about 2000 RPM, then you have 3.54. If the engine spins around 2500 RPM then you have 4.10.
Old Nov 17, 2007 | 07:56 AM
And I should have known that
Old Nov 17, 2007 | 12:56 PM
SIXSLUG's Avatar
If all else fails and you aren't sure about speedo accuracy or if the gears have been changed out jack up the rear wheels put her in neutral and put a piece of masking tape on the driveshaft after centering the valve stem on the wheel at 6 o'clock. Now turn the tire one revolution while counting the driveshaft turns. A little work but surefire. Kurt
Old Nov 17, 2007 | 01:19 PM
rolling18's Avatar
Originally Posted by oldblues
hi
ahh excellent !! i did not think of counting it manually lol!! thanks guyz!
BubbleChaser
May 2, 2004 04:14 PM
Hitchhiker
Nov 13, 2003 02:04 PM
mthomas
Nov 6, 2003 10:53 AM
kerrdog
Apr 1, 2003 10:06 AM
Hummin Cummins
Jan 27, 2003 08:31 PM
