Air Conditioning Repair Ripoff !
Well folks, I hate to say it but I got ripped off on a simple A/C repair job.
I had developed a leak in the suction (LP) line area at the gas inlet port (where you add gas). The nipple is welded to the pipe and it was in the joint that I had a very small pin hole allowing gas to escape. I had the leak checked and determined by A/C outfit.
Not realizing myself that the whole hose needed to be replaced - suction line from the evaporator down to the compressor and then from the compressor outlet to the condenser inlet. The line comes as a one piece unit and has surprisingly few connections - a clip over the failed suction end where a seal sits, two bolts - one at the compressor and one on the condenser. I agreed to a replacement being installed
This is where it gets interesting ! I am in Prince George, BC Canada, so the prices might be a bit off compared to the US. So be patient.
This hose unit or arrangement cost $356.93
Installation, leak check, pump down and gas recharge labour $255.00
Gas charge for 134a $90.00
Tax (HST) $84.23
Total $786.16
It was quite a shock seeing the bill.
The part cost in the US is around $112 give or take a few dollars.
The installation shouldn't be much more than an hour in time.
Not having a vacuum pump makes a difference.
Putting gas in the system is not hard - in fact very easy.
Thought that posting this might save someone else from getting taken to the cleaners. I know that AC techs do a good job and for the most part, are very concientous and reasonably honest. The part price really gets me - triple the cost of the item in the US.
If you have a problem with this part - buy your own and save money. The hardest part would be the evacuation or pump down to get rid of moisture in the system. The rest is pretty easy.
I am not knocking the A/C technician, just the cost. And of course the part is Chrysler only parts - so I was told. Therein lies the rub - not like twenty years ago when an AC line could be removed and replaced with one made up out of stock hose and fittings.
Ok - my moan is off but I don't like having an empty wallet (am retired).
Cheers
mariner
.This is where it gets interesting ! I am in Prince George, BC Canada, so the prices might be a bit off compared to the US. So be patient.
Tax (HST) $84.23
Total $786.16
Cheers
mariner
Cummins Guru
If you think that is expensive try going food shopping on a budget Everything goes up except my pay check that has been going down lately. Next time try internet search first or a wrecking yard. Senior discount or AAA discount are another way to save money. Don't know if you have that option in Canada but if you do it worth a try.
I've gotten in the habit of negotiating complete price in writing before authorizing. Also try just beating them down. I cracked the front windshield in the 85 Mercedes. Glass man said it had to be replaced, not repaired. Best price I found was $250 installed lifetime warranty.
Hmmmm, what would it cost to replace wife's windshield? ~ $180. Ok, How about a discount for both? 15%. Now I want to talk to the wife. It's her car. Call back...wife doesn't want to do it but if you'll give me the 15% you can do it tomorrow. Got the deal. Will wait until everything is done correctly before paying. Warning: Don't EVER let a contractor get ahead of you - they go into hiding rather than finish the job. (Old $4,000 lesson)
A/C Leak
You could have taken the hose to a hose shop and had it welded. if the leak was in the rubber part of the hose the shop can replace it a LOT cheaper than the factory one. my brother needed an A/C hose like yours, for his mercedes 300 diesel. the factory wanted $750 for it. we had a hose shop replace the 2 hoses in the set-up. including 4 weld joints the whole bill was $90 !!! most of the after market hose is a lot better than the factory stuff. sorry that you got ripped!! most hydraulic hose shops also make A/C lines. check it out next time you need A/C lines. the shop hosed you on the price of the 134a. list at auto zone is $9 a pound !! Sam`s club has it for $5.50 a pound. they were really greedy on their labor, too.
Thought the info might be of help to someone else.
Yes, I needed others to confirm that the rates charged were excessive - that just confirms my feelings.
If anyone wants to know who not to use in Prince George, I will be happy to provide the information by way of a PM.
Not often I get taken - but this time I did. Lesson learned as they say and I know for a fact that there will be no work going their way from a satisfied customer - quite the opposite. I will be recommending that people do not use them.
Cheers
mariner - embarrassed and angry
Cheers
Tangent Topic: Have I been clear in stating that AGR makes expensive crap? - from my personal experience.
Thanks for the info - those prices I can afford
I have used the engines vacum pump and it worked just fine. I just shove some hoses together over the 134a can adapter and let it run for about 45 min. Does Canada have some green/ luxury taxes on AC parts and supplies?
