After Market Carpet? Good? Bad?
Old Jul 22, 2013 | 05:39 PM
Clik's Avatar
Question After Market Carpet? Good? Bad?
My A/C outlet clogged and soaked the jute backed carpet and the foam backed rubber matting under the dash. I cleared the stoppage.
I pulled the seats out and removed the carpet that now smelled like a swamp.
I cut the foam backed rubber up as high as I could because it looks like to replace that means pulling the dash(?).
Dodge Dealer says my 97 club cab 3500 Cummins 4X4 is obsolete and doesn't carry parts. So I'm wondering who makes a good replacement carpet and who sucks.
Any input would be appreciated.
Old Jul 22, 2013 | 08:53 PM
SIXSLUG's Avatar
Try LMC truck, they probably bought all the OEM stuff anyway, or you can get some better stuff from a carpet place and make your own...
Old Jul 23, 2013 | 08:30 AM
patdaly's Avatar
Clik, run it for a while to make sure you got it. On Greenie, I thought I had it several times, only to be rewarded later with another swamp.
I finally figured out that even setting, my fan was drawing enough air to keep the AC drain from running, put a 5/8" 90 degree water pump bypass hose on pointing down, and have been dry ever since.
As has been pointed out, LMC truck, or ACC carpet
http://www.accmats.com/
Littlle over 250 bucks for a 97 Ext. cab.
Old Jul 23, 2013 | 08:50 AM
Hodge's Avatar
Buying residential carpet and making it fit doesn't work well, unless you are a carpet master. Buy the preformed carpet. It is better suited, anyway. Residential carpet has longer fibers, will wear quicker, and will not have the proper backing for life in a truck.
Most of my career has been spent in flooring, and I have carpeted WAY too many campers and boats. Residential carpet is not the better solution.
Old Jul 23, 2013 | 06:03 PM
SIXSLUG's Avatar
I was thinking outdoor or boat stuff....
Not deep green ****, you know to match the smell!!!
Personally I would go with stock stuff....
mstep3
Jun 25, 2010 11:07 PM
crabbelle
19
Dec 25, 2007 05:03 AM
cheapskate
Nov 12, 2007 02:36 PM
Mslaughter
Jun 4, 2006 12:25 AM
ten8fiftyone
Aug 11, 2004 10:34 AM
