accessing A/C blend door?
Old Jun 4, 2007 | 09:33 PM
mr T's Avatar
how can I get to this? I understand it is under my dash. in the winter I dsidnt have much heat unless I had the truck in circ. mode...
thanks
Andrew
Old Jun 5, 2007 | 06:10 PM
chuxtruk's Avatar
Have you flushed your cooling system yet??
The reason I ask is that my dad was experiencing the same problem. But when he took it into the dealer for the fix, they found a plug in the cooling system and backflushed it. $$ wise he was LUCKY!! All due to a lack of use as they winter in AZ and don't use the heater much. Seems like you have to cycle that thing whether you use it or not as otherwise it can plug up from lack of use.
Dash removal by the dealer is spendy but I think to get at that blend door that's what has to be done. Better to try the cheap & easy route before attempting that one. Good luck!!
Old Jun 5, 2007 | 07:27 PM
mr T's Avatar
who or what is this "dealer" you speak of? (no need for a dealer when u have a 12 valve)...I prefer not taking off the steerign column to access this though
Old Jun 6, 2007 | 03:00 PM
Break Away's Avatar
Check the little motor that operates the blend door for proper operation...It is located at the bottom of the dash just above where a passengers left foot would be...Also do a search here for blend door/no heat topics...lots of info to read.
Old Jun 6, 2007 | 04:33 PM
patdaly's Avatar
I've not had mine apart yet, but according to the Mechanics at the dealership, dash removal is easy, you just lower the column, then 2 bots at the bottom of each side of the dash, and the 4 or 5 at the top, plus unplugging the connectors. Then you can remove the whole heater assy and R&R the core on the bench.
biglar
Oct 14, 2006 02:06 PM
DmaxEter
Apr 12, 2006 10:35 PM
97Dually
May 23, 2005 06:04 PM
troutstalker
May 24, 2003 10:34 PM
