ac not cold at all
Old Apr 16, 2006 | 11:18 AM
ncdodgeman20's Avatar
ac not cold at all
i have a 2001 ctd 2500 with ac well yesterday i went to runing the ac but it never got cool it was just like the outside temp so i went by autozone to get one of those do it yourself ac recharge well i check the coolent in the ac system with a gauge that comes with the kit but the gauge said the coolent was fine but then i noticed that the ac pump would come on then it would buld pressure then it would cut off then lose the pressure and do it all over again.so does anybody know anything about the ac on our kinds of trucks???
Old Apr 16, 2006 | 01:30 PM
kawi600's Avatar
Is the AC compressor clutch engaging properly? Theres a connection at the evaporator where the pressure switch is. You can jumper across that to rule out a bad switch.
Theres also a relay in the engine compartment fuse box you can try.
Old Apr 16, 2006 | 03:55 PM
infidel's Avatar
Sometimes just tapping on the pressure switch with a wrench will make it work-- for little while. Then you will know whether it needs replacing.
Old Apr 16, 2006 | 06:16 PM
J BODY's Avatar
I know quite a bit about the a/c systems on our trucks and the first thing you need to do is post some psi readings low and high. Get it looked at by a pro, or at least beg, borrow, buy a set of gauges and get us something to work with. My blindside guess is that you are going to need a compressor.
Old Apr 17, 2006 | 07:16 AM
kawi600's Avatar
My pressure switch came back to life after I re-seated the connector. Looks like to get at it and replace it youd need to drain off the refrigerant =(
Old Apr 17, 2006 | 08:46 AM
robert chilton's Avatar
Anyone ever have luck rebuilding the sanden compressor? I have a torn valve in mine causing it to work a little some of the time. Looks like I can order the parts for $100 but that alot cheaper than $350 for a new one.
Old Apr 20, 2006 | 12:03 AM
tenbrooks's Avatar
I have one available if your interested
Old Apr 20, 2006 | 08:35 AM
BarryG's Avatar
After the first year on my 01 my ac started getting weak. I added a bit of freon or whatever it is these days and it came back. I have had to add it every summer now and it seems to last the summer. On mine it seems if I just fill it to the high side of the acceptable range it makes the difference. Every year when I add it it is still in the acceptable range but just on the low side so I fill it to the high side and then good ac. There obviously is a small leak or something but for the cost of a can of freon once a year not sure it is worth chasing for such a small leak.
Hydrauk
16
May 7, 2008 02:58 PM
akhunter68
Oct 31, 2006 05:07 PM
joel
Jan 22, 2005 08:59 PM
BEHRMAN
Dec 24, 2004 11:05 PM
wings
Nov 8, 2004 05:32 PM
