AC bearing change
Old Aug 31, 2011 | 12:33 PM
Junk Man's Avatar
AC bearing change
My air conditioning compressor recently started squeaking while the compressor is engaged. Turn AC off & no squeak. I'm thinking bearing but haven't found a diagram to know that can be changed.
I recently did the heater core and the AC is cold. The less I have to disturb the radiator or AC the better. The usual "I want to be down as little as possible" applies.
So...Can the bearing be replaced?
Can it be replaced without removing the compressor?
Does the radiator have to come out?
Is the bearing a Dodge only part or is the bearing a standard size?
We have a bearing supply house & I could order from there if only the bearing needs to be changed.
It looks like bearing would be pressed into the pulley (P1 #3) of the pdf. In which case, I may be able to press out & simply replace. Comments?
01 FSM pages attached
File Type: pdf
Old Aug 31, 2011 | 12:59 PM
06RAM2500's Avatar
If it does it only when the compressor is running, then the compressor itself is going or the clutch isn't engaging all the way.
Old Aug 31, 2011 | 01:11 PM
Junk Man's Avatar
What part of the compressor? Clutch can be replaced. How do I test for which it is?
Old Aug 31, 2011 | 01:33 PM
06RAM2500's Avatar
Remove the belt then check the pulley for play.
Old Sep 24, 2011 | 05:48 PM
wmcclay's Avatar
before replacing anything check voltage at clutch by backprobing at connection, squeaking is usually clutch slipping
Old Sep 25, 2011 | 08:34 PM
Junk Man's Avatar
Thanks. That is an idea I hadn't seen. Much too expensive to mis-diagnose & install the wrong parts.
Old Sep 26, 2011 | 08:42 AM
wmcclay's Avatar
Check your air gap between belt pulley and the part that attaches to compressor, proper spec is available from dodge or compressor mfg. I have a compressor manual if need be. You will need a special tool to remove part and remove shims untill proper air gap is set
pmtg
Jul 19, 2007 08:47 PM
Rattletrap1
Jul 11, 2007 12:12 PM
wadecool
Jan 12, 2007 11:39 AM
Joseph H. Smith
16
Jan 6, 2007 08:13 PM
