ABS the problem?
Old Jul 24, 2010 | 09:21 PM
b1mmuo27's Avatar
ABS the problem?
I just purchased a 37 foot gooseneck trailer. When I move it in tight spots with lots of braking I notice I loose the brakes. As if I had pumped them & the abs stopped them working. It happened yesterday when backing into a tight spot. After hitting the brakes in rather a quick succession it appeared I had none & had to push REALLY hard on the pedal to stop. The truck is a 1996 RAM 2500 extended cab & long box. It has a 12 valve Cummins with 485,000KMs on it. It has rear wheel ABS. Any ideas?
Old Jul 24, 2010 | 09:58 PM
CoastalDav's Avatar
Something similar happened to my 2000 3500. Mine did the same thing and later I had no brakes at all. The small tubes in the abs system had rusted out and were leaking. I was lucky to make it to a repair shop. It would have hard to do without the 6sp tranny and exhaust brake I had in that truck.
Old Jul 24, 2010 | 10:17 PM
b1mmuo27's Avatar
Thanks my brakes lines are ok. Not rusty they have been replaced.
Old Jul 25, 2010 | 08:17 AM
blackimpala's Avatar
The vacuum system in our 96s is not that good, alot of braking @ idle or low RPM will use more that the pump will handle. Its just the nature of the beast.
Floyd
Old Jul 25, 2010 | 02:06 PM
b1mmuo27's Avatar
Thanks that's what I was thinking last night. In the winter when I start it up & pull the parking brake off, I usually have to wait a minute for the brake light to go out as the vacuum has not built up enough. If I don't, same thing I push like hell to stop it. There must be a fix for this though? Pretty dangerous when backing up a trailer.
Old Jul 25, 2010 | 02:23 PM
BigGreen's Avatar
I could see that.
Old Jul 26, 2010 | 09:07 AM
I have read that some people have added a vacuum canister to give it more reserve vacuum.
Floyd
fitzydog
21
Oct 11, 2017 12:09 PM
DodgeRam24V
0
Jan 7, 2012 06:02 PM
BigBore050
Mar 9, 2010 11:46 PM
sssmaly
Jul 13, 2007 12:57 PM
mr T
Feb 24, 2007 06:42 AM
