ABS/BRAKE Lights?
Old Apr 21, 2003 | 04:39 PM
gofastman's Avatar
ABS/BRAKE Lights?
I have a 98 12v and the ABS/Brake light has come on and will not go off.<br>Is there a way to read the code with out a box to tap into the computer? It has come on in the past, but then go off if I turned off the ignition, now it is on and will not go off, when I cycle the switch.<br>Any Ideas?<br>Thanks,<br>Allen
Old Apr 22, 2003 | 01:08 PM
Dieselhead's Avatar
Re:ABS/BRAKE Lights?
I have this same issue...See my post on the 24 V engine/drivetrain board. I know what I did to cause it, now I just need to know how to fix it!<br><br>http://www.cardomain.com/id/rattlindodge
Old Apr 22, 2003 | 01:13 PM
phox_mulder's Avatar
I believe Autozone's have a code reader, can tell you what code and clear it once it is fixed.<br><br>The key on-off-on-off-on works on 2000 and up trucks I think.<br>(works on mine anyway)<br><br>First thing I would check is the sensor on the rear differential.<br>Take it out, clean it up, and reinstall.<br><br>I believe there is an antilock brake sensor on each wheel as well, try cleaning them also.<br><br><br>phox<br>
BuckyKatt
Feb 8, 2013 01:12 PM
quadstar
Nov 20, 2009 05:23 PM
polaris800sp
Nov 13, 2008 05:35 PM
kpmccarthy
Apr 23, 2008 07:42 AM
