ABS & Brake lights??
Old Oct 13, 2002 | 08:45 AM
Dusty 96's Avatar
a friend of mine has a 95' 2500 4x4 ctd, w/ a 5 spd. a while back his ABS & Brake lights came on , i put a new ABS sensor (the one on top of the rearend) in it & the lights still won't go out, any ideas???? thanks, dusty
Old Oct 13, 2002 | 09:29 AM
Bob Beauchaine's Avatar
Re:ABS & Brake lights??
Try the micro switch on the brake pedal under the dash. If it is out of adjustment it will cause the brake lights to stay on. Good luck<br>Bob
Old Oct 13, 2002 | 01:11 PM
USMC64-70's Avatar
I had a similar problem on my 1995 2500 a few months ago. It ended up to be caused from a worn out vacuum hose coming off the engine and going to the brake vacuum. Hose would partially collapse under pressure. Worth checking out. ;D
Old Oct 16, 2002 | 12:49 AM
yomitch's Avatar
clean with contact cleaner or wd 40 the connector going into the sensor then pull the negative terminals to the battery wait 30 min or so and put them back on and computer should reset it
BuckyKatt
Feb 8, 2013 01:12 PM
quadstar
Nov 20, 2009 05:23 PM
polaris800sp
Nov 13, 2008 05:35 PM
