ABS & Brake light
Old Jan 15, 2010 | 06:19 PM
bowhunter57's Avatar
From: I live in Bernville Pa but where I want to live is Colorado
ABS & Brake light
my ABS and BRAKE light come on every once in a while if I shut off the truck and restart it they don't come on again for a few more days, any idea's
truck is a 1998 1/2, 2500 quad cab, automatic. thanks bob
Old Jan 15, 2010 | 07:08 PM
A. Bomb's Avatar
Does the brake light come on first (or never turn off after the truck is started) or do they both come on at the same time?
Old Jan 15, 2010 | 07:37 PM
I will be driving along an both lights come on at the same time
Old Jan 15, 2010 | 07:41 PM
mishkaya's Avatar
Usually it's the rear wheel speed sensor going out that will cause this. However, if yours is intermittent; it could be the bearings going bad causing issues with the front wheel ABS sensors (if you have 4 wheel ABS). Best you can do is check the wiring and all the sensors for chafing or corrosion on the connectors.
Old Jan 16, 2010 | 06:08 AM
Hodge's Avatar
Mine did that- it seems to be a very common problem.
If I have learned one thing, it is that there is no quick fix. The rear sensor is one; the wiring harness for that sensor can chaff and be a problem; you can have a problem with the front sensors; in my case, there was a vacuum leak, causing problems with the abs. Both lights would intermittently come on, and then, finally stayed on all the time. Once the leak was fixed, the abs works again. And, no lights.
You need to get your truck scanned. That is the only way to pinpoint where the problem lies.
The first thing I replaced was the rear axle sensor, and that was not my problem.
Old Jan 16, 2010 | 07:33 AM
RowJ's Avatar
I thought both BRAKE and ABS lights meant a front ABS sensor. It did for me.
RJ
Old Jan 16, 2010 | 08:11 AM
sheriffav8r's Avatar
Both lights mean any sensor is not reading properly. It could also be a host of other issues, but that is the most common. The sensors are plastic cased and, for me, seemed to get brittle after so many years. Even if they are not your problem, I would replace at least the rear one every 5-8 years or so. JMHO
azjeff
Aug 4, 2012 09:57 AM
Joey-D
Dec 12, 2011 12:52 PM
BigBore050
Mar 9, 2010 11:46 PM
mr T
Feb 24, 2007 06:42 AM
Alexjoz
Sep 1, 2005 10:00 PM
