abs and brake light on
I have had these lights on for a wile. I have checked vacuum , replaced rwss checked wiring and no luck. The truck only has rwal has any one had an exciter ring go bad. I have not pulled the diff cover yet but thought i would ask first. Also the lights don't come on till 40mph but speedo works fine and no cruise control.
thanks, JOE
ps. it is on the 01
thanks, JOE
ps. it is on the 01
Did you do the pads recently? If so, the system might need to be bled. Or they gave you the wrong pads. Mine did that when I changed front pads. I drove around for a while with the lights on, then bled the brakes, the lights went off.
MMMmmmm.... Grits!!
fitzydog
21
10-11-2017 12:09 PM
Joey-D
12-12-2011 12:52 PM
mr T
02-24-2007 06:42 AM
