Abs?
Old Dec 27, 2005 | 10:44 PM
FORDNOMORE's Avatar
Abs?
Hello, I noticed that the ABS light does not come on when I start my truck. is this normal for a dually? the brakes seem to work fine just no ABS. I checked the fuse for the ABS and it was good so where should I look? I should mention that I have owned the truck for only a few months and that the previous owner took great records of everything done to the vehicle.
Thanks
Old Dec 28, 2005 | 12:40 AM
newriverSpecon's Avatar
Probably a bulb. It should come on when there is an issue. Not stay off.
Randy
Old Dec 28, 2005 | 10:07 AM
ccmckee's Avatar
Yeah probably just the bulb burnt out, cause it shouldcome along with the other lites for the lamp check sequence at start up.
Old Dec 28, 2005 | 10:24 PM
FORDNOMORE's Avatar
Yeah, probably be my luck that the bulb burned out because it was on all the time. I will look at the sensor and try and do a little more trouble shooting. I will let you all know what I find out. Please keep the Ideas rolling in.
Old Dec 29, 2005 | 08:30 AM
Mopar1973man's Avatar
Every time you turn you key to ON its basically a 2-3 second bulb test for the console.
On 2000 and up you can hold the TRIP button down and turn the ignition key to ON the release the TRIP button. This will start a diagnostic of the console. Odometer test, bulb test, and guage test.
So if the bulb isn't lighting up then it burnt out! Time to chnage the bulb...
You can also check the fuses (under the hood and in the cab)
fitzydog
21
Oct 11, 2017 12:09 PM
DodgeRam24V
0
Jan 7, 2012 06:02 PM
BigBore050
Mar 9, 2010 11:46 PM
sssmaly
Jul 13, 2007 12:57 PM
mr T
Feb 24, 2007 06:42 AM
