"99" Current Draw From Fuse #12 I.O.D.
Old Oct 22, 2006 | 05:58 PM
Geico266's Avatar
I have a .45 amp current draw (everything off) from the #12 fuse station marked I.O.D. When I pull the fuse the current draw stops & so does the radio & inside lights. The radio has it's own fuse so I am confused.
What can be the problem?
Old Oct 22, 2006 | 06:04 PM
infidel's Avatar
IOD = Ignition Off Draw
The power is there for the clock and radio presets. Some IOD power also goes to the PCM to remember odo, trip miles, power seat belts and dome lights.
Old Oct 22, 2006 | 06:18 PM
Geico266's Avatar
Is it normal to draw .45 amps? That seems like a lot.
Old Oct 22, 2006 | 06:25 PM
J BODY's Avatar
Are you using a shunt to check the amperage draw? Some DVOM's won't let enough current pass to let the controller "fall asleep". Often you'll have to hook up a larger gauge wire along with the dvom and let it sit 10 min or so and see what happens. If it drops below .025 that should be ok.
Old Oct 22, 2006 | 06:29 PM
infidel's Avatar
That does seem like a lot.
Can't remember the exact spec but under .01A draw sticks in my mind. Manual says the IOD will run the batteries dead in 21 days if the engine isn't started and batteries charged.
Most of the time when folks run into high IOD the cause is the seat belt module. Not really sure if your '99 came with one though.
You need to be careful measuring IOD, there are some circuits that will be energized for up to half an hour just from opening the door.
Old Oct 22, 2006 | 06:37 PM
Geico266's Avatar
That must be what I'm seeing. I know just enough about electricity to be dangerous. I ruined a set of Optinmas by letting it draw down like this, but I think it was the power window Bypass I did. It leaves the green indicator lites on in the doors. I also had a B&D Trans Loc go bad and draw current all the time.
Old Oct 22, 2006 | 06:41 PM
infidel's Avatar
Just to clarify
When I said be careful what I meant was you won't get a true IOD reading if the doors have been opened in the last half hour.
Old Oct 22, 2006 | 07:03 PM
Geico266's Avatar
Just to clarify
Yea, I'm just gonna let it go and see what happens. I can test the batteries in the AM & see what it reads in volts. The old Optimas would drop to 12.18 over night. Sears replaced them free.
Old Oct 25, 2006 | 12:55 PM
Geico266's Avatar
Well, infidel is right again. Over diagnosis on my part. After replacing the batteries and letting them sit overnight they are still 12.65 volts.
Life is good when infidel is around.
Old Oct 25, 2006 | 06:02 PM
linetrash75's Avatar
My truck also pulls .45amps though IOD, I know I have the bad seat belt controller if I unplugg it under the seat batteries stay up, if I leave it plugged most of the time no start in the morning.
Jed
Old Oct 25, 2006 | 07:11 PM
Dr. Evil's Avatar
Interesting....I ran into the same issue with the IOD fuse last fall. You might recall because you made several posts in that thread Geico. I chased around the truck with a meter for at least a week or two and didnt really resolve anything. Hasnt caused me any trouble since. And yes,m it was drawing in the neighbourhood of 400 mA..
1999 duallie
Mar 12, 2013 07:05 PM
metermatch
Dec 12, 2009 09:37 AM
1993rollincoal
Mar 2, 2008 11:08 PM
hotdram
18
Nov 5, 2004 06:16 AM
MNISB
Oct 23, 2003 04:26 AM
