99 2500 cluster NO illumination Turn arrow ON
Old Jun 21, 2009 | 08:12 AM
smokinram99's Avatar
have no illumination by 1 week in my 99 2500 cluster....its completely dark and the only lights on are the 2 turn signal arrows that are constantly on...! even the OD OFF warning light not function..all function properly, instruments are ok, its only the illumination.. im not very familiar w electronics so where can I start? anyone w a similar problem...
thanks
Old Jun 21, 2009 | 08:14 AM
took off the cluster and cleaned the two harness on the back w contact cleaner but they looks very good...w the cluster in position sometimes it illuminate and sometimes not; if I move it a bit it illuminate and function good for a while...maybe its a contact problem on its back...pins and harness looks perfect.. I've noticed, w the engine off, that when I turn on the lights, and cluster not illuminate(both LH and RH turn signal lights on and flashing intermittently) I hear a bad noise from thre engine bay...like a relay that engage and disengaged continuosly, its the fuel system relay under the fuse box in the engine bay; and even the "valves"wires/connection bolted to the inner LF fender, under the left battery, I think its the stuff for the heater grid(cables goes onto it)...but I dont know what that concern w cluster illumination...
I need help, thanks
rob
vepchl
Aug 3, 2012 04:58 PM
biglou
Jul 7, 2010 08:30 AM
biglar
Apr 4, 2008 02:45 PM
danimal 95
May 7, 2007 11:41 AM
