98 extended cab back door won't open
Old Jul 14, 2023 | 05:31 AM
barngal6's Avatar
My passenger rear door (suicide door?) won't open from the inside. Very inconvenient that the front passenger has to let the back passenger out, and not safe either.
When handle is pulled, the door latch moves but not all the way to open.
Is it a spring, or? How to repair?
thanks
Old Jul 14, 2023 | 09:22 AM
texasprd's Avatar
A Google search for "98 dodge ram rear door won't open" gets lots of results, and several possibilities are mentioned. Apparently there is a cable that might snap, upper/lower latches that can freeze up with rust - and probably other possibilities. Those were just what I saw in part of one search result.
Old Jul 25, 2023 | 12:46 PM
barngal6's Avatar
Thank You. Im trying to narrow it down.
The handle from outside opens the door easily.
The handle from inside moves the latch partway but not enough to open. I would guess its a spring but havent seen that as a problem in whative found. I do plan to get into it but just wondering if someone else had the same symptoms
Old Aug 21, 2023 | 07:16 PM
barngal6's Avatar
OK I have looked at alot of posts but haven't found my answer yet.
The rear doors open from the outside. A passenger inside pulls on the handle and it almost opens, but not quite--there is about 1/8" more movement needed by the rods to operate the top and bottom latch mechanisms.
The latch cables are both new. The problem is the same on either back door--almost opens from the inside, but not quite. Opens find from the outside. If i knew how to adjust the rods I think that might be the answer but they don't seem to thread up or down in the rod holder...
Any help would be appreciated...
Old Sep 7, 2023 | 11:29 AM
SIXSLUG's Avatar
Bend a small kink in them to shorten....
highwayman
Jul 30, 2014 09:15 AM
Tyeopalinski666
Jun 29, 2014 02:46 PM
stealman1
Dec 6, 2009 05:49 PM
pwregan
14
Sep 18, 2009 07:33 PM
swmnkdinthervr
Jan 30, 2006 05:34 AM
