94 pcm same as 98?
Old Aug 11, 2013 | 07:50 PM
1320's Avatar
94 pcm same as 98?
I have a 56040139 AB pcm.......in my 98 3500 12 valve 4x4 stick.
I found a 56040139 AB pcm, that is said to be from a 94 3500...
Are all the 94 to 98 pcm's the same if they are optioned the same? Like a 94 3500 (that should be a stick ) be the same pcm as a 98 3500 with a stick.
I kinda figured a 98 might be different, cruise control? maybe other stuff, but Im not familiar with 94-97.....I only kn ow the dash looks different but that doesnt mean it works different.
Anybody?
Old Aug 11, 2013 | 10:24 PM
torquefan's Avatar
Generally speaking, with Dodge, if the part number is the same, the PCM is the same. If the calibration changes, the PCM gets issued a new part number. Example, with the same year truck, a manual transmission truck will have a different calibration than an auto transmission truck, therefore will have a different PCM part number.
I wouldn't have expected a 94 and 98 to share a PCM, but if the part numbers are the same, then according to all my experience with Dodge, they will interchange.
To be double sure, you might want to consult a dealer partsman with the serial number for each truck and verify that he comes up with the same number for both trucks.
Old Aug 12, 2013 | 01:22 AM
1320's Avatar
i think your right, and the one I found that is said to be from a 94, is probably from a 98 and they dont really know. A search revealed that pcm number only linked to 98's.
edit: talked to the seller and revealed that his 4 looks like an 8 sometimes and he bought it for a friends truck (trying to fix it) It was a cps problem, so the pcm wasnt needed.....and the truck is a 98....so I boiught it.
oliver foster
Aug 11, 2011 12:21 AM
J Lent
60
Nov 3, 2009 09:14 PM
Big Perm
Dec 18, 2007 08:44 PM
jmccart
Jan 18, 2007 03:26 PM
