36K Warranty Approaching
My 36K warranty will probably be ending in the next month or two; any suggestions on what I should carefully inspect? I have not had any problems yet except for a power seat plug that I pulled apart (i dont think warranty would cover it) and I am still trying to decide if my truck is wondering to the right while driving (I think it is, sometimes it does and sometimes I can blame it on the wind or road). Is alignment even considered a warranty issue or maintenance? Any other ideas? Thanks
My truck wanders more than I think it should. Was having some other work performed at the dealership and asked them to check it out. They told me it was within spec. which must be a pretty wide range. I didnt really want them messin with it anyway. I figure I will get one of Darins steering stabilizers if it loosens anymore.
Any alignment issues are usually only covered 12/12. My 01 wanders a bit too and I've noticed this on nearly every 4x4 2500 I drive. I did the alignment on mine and set the front toe +.15 degrees and it helped quite a bit as it was at zero. I wouldn't be afraid to go as high as +.20 on the toe, assuming everything else is ok (track bar, ball joints, tie rods, etc...)
Hoss
16
Nov 12, 2004 04:19 PM
Thirsty600
Aug 30, 2004 03:54 PM
02Texas_Rattle
Apr 14, 2004 11:06 AM
