2001 soft brake pedal after replacing caliper
Hi, I replaced both front brake calipers on my truck. Did left front first, drove the truck then ended up replacing the right front as well. After doing so, I don’t have brakes. The pedal is firm with the truck off but gets soft when I start it. Do I just have air in the lines there something else? All bleeder screws are on the top as they should be.
Bleed the system, after replacement ?
You sure the bolt which attaches the brake hose is tight enough, with new copper washers ?
Air infiltrating the system causes no brakes or a soft brake pedal.
It's best to replace the hoses if they're original, of you feel they're being compromised due to age.
frostytj
Jan 6, 2011 10:28 PM
96CERon
14
Dec 31, 2006 10:44 PM
