1999 2500 front brakes
Old Sep 30, 2012 | 08:35 PM
d man's Avatar
does anyone if bearing and rotors will switch from 2001 or 2002 to 1999 2500 so pulling the rotors does not involve pulling bearings?
Old Sep 30, 2012 | 09:14 PM
high bid's Avatar
I think it's a different set up but....yes this would be great.
Old Sep 30, 2012 | 10:17 PM
torquefan's Avatar
I believe the newer rotors are a larger diameter and won't fit with your 99 calipers that bolt to your knuckles. The 2000 and newer setup has much better braking, but it's always been my belief that you need to change up the complete front axle assembly to make use of it.
Old Oct 1, 2012 | 06:12 AM
high bid's Avatar
Or can you change things from the knuckle out...ex. when doing ball joints?
Old Oct 1, 2012 | 10:24 PM
torquefan's Avatar
No, I don't think so. The way the ball joints mount is totally different. On the earlier trucks, the joints press into the knuckle. On the later trucks, the joints press into the end yoke of the axle housing.
Old Oct 2, 2012 | 11:42 AM
Redlinear's Avatar
You'de have to change the front axle/differential housing. Then, that's a whole other can of worms.
Control arm bolts are larger diameter requiring changing the front control arm bushings.
Sway bar would need to be changed as well.
You'de also have to make sure the front housing you chose had the vacuum axle disconnect on it too. (some 01,02's front diffs didn't have).
leeboy
Apr 6, 2014 10:44 PM
d man
Sep 28, 2012 12:13 PM
turbo diesel
15
Sep 7, 2011 03:56 AM
mr4732
Oct 21, 2007 05:12 AM
wildcargo
Nov 29, 2005 04:20 AM
