Won't start with Key
Old Aug 29, 2006 | 10:15 AM
White00's Avatar
Need a little help here guys and gals. I got into my truck this morning and it would not crank. When I turn the key everything seems to be working like normal, but no cranking. I checked the fuses and they were all OK. (in dash and under hood) I put my test light on the solenoid and there is no juice going to it. Any thoughts on what to check test? Right now I am just putting it in neutral setting the brake and using a screwdriver to start it
Thanks
ADAM
Old Aug 29, 2006 | 10:43 AM
1-2-3's Avatar
Just a plain ole guy
Nuteral saftey switch.
Can you wiggle the shifter and make it crank?
Old Aug 29, 2006 | 11:27 AM
White00's Avatar
Good thought, but its a five speed. I figured bufore I went under the dash for the clutch switch I would see if anybody else had the problem and a simple fix.
Old Aug 29, 2006 | 12:16 PM
1-2-3's Avatar
isn't there a switch on the clutch pedal?
Josh Robbins
Jul 11, 2014 12:18 AM
fireram
0
Jan 24, 2013 10:19 AM
jmccart
13
Oct 1, 2008 09:39 PM
akfroggy
Dec 8, 2007 05:47 PM
billv45
Dec 7, 2006 05:57 PM
