Wont go into 4X4 ?
Old Dec 4, 2005 | 01:30 PM
dewclaw's Avatar
Wont go into 4X4 ?
I was out with grandad the other day and got into a slick spot.
I shifted the transfer case into 4 low. It felt fine but the dash board '4x4' lite didnt come on and it was obvious that it really wasnt in 4x4. Good thing that I had a place to get a running start at the slick hill or I would still be there.
What should I check first ? (2nd & 3rd.....etc)?
I have a 98.5 with a manual tranny.
Thanks ,
Dew.
Old Dec 4, 2005 | 01:52 PM
Big Deezul's Avatar
Make sure the vacume lines to the transfer case are hooked up ...and hooked up in the right spot.
Old Dec 4, 2005 | 02:18 PM
TNutcher's Avatar
Our 01 Ranch truck has the same problem, also on it the directional valve *** for the a/c, heater, defroster doesnt work and its also vacum oporated
TNutcher
Old Dec 4, 2005 | 03:02 PM
dewclaw's Avatar
Well,, HeeHee, it was the vacuum lines back by the X-fer case. Both torn off. I did remember going over a lot of nasty brush during deer season. The brush must have torn them off. Works fine now .
As for the last post .
The Vac lines are pretty easy to trace, start at the Vacuum pump ( right under the Injector pump. Make sure its hooked up , if its not , none of your vacuum operated things will work .
Thanks for the lead
Dew.
Old Dec 4, 2005 | 03:27 PM
Big Deezul's Avatar
No problem. I just remembered when I put my tranny in I had em hooked up backwards and it wouldnt go into 4wd...of course I dint find out untill I was stuck and needed it
Old Dec 20, 2005 | 12:36 PM
Fernando's Avatar
How was it hooked up backwards? Where the lines change to metal under the tranny? Or is it posible to have it connected wrong above the trany (4lines in a block connector)??
Just wondering cause mine indicates that I'm in 4WD but its not.
Old Dec 20, 2005 | 01:57 PM
Big Deezul's Avatar
if I remember it was above the tranny...I did it when I had the tranny out
kingofdodge7131
Jan 19, 2011 05:39 PM
V.R.Wheeler
Aug 4, 2007 01:00 PM
getblown5.9
Oct 20, 2005 09:16 AM
srowen
May 17, 2003 10:39 PM
powerwagon440
Jan 31, 2003 01:10 AM
