When to replace u-joints?
Old Jan 24, 2009 | 12:53 AM
ldornak's Avatar
How do you know when it's time to replace the u-joints in your driveline? Are there any symptoms to look for?
Old Jan 24, 2009 | 01:02 AM
nickg's Avatar
when you have noise or vibration or the U-joints are loose,
Old Jan 24, 2009 | 05:07 PM
dozer12216's Avatar
High frequency load induced drive line vibration or visible looseness when shaking joints. Or rust coming out of seals.
Old Jan 24, 2009 | 07:31 PM
ldornak's Avatar
Is the u-joint vibration a different feel than a tire out of balance? I currently don't feel a vibration in the steering wheel, but if I hold the stick, I can feel a vibration that feels more than normal.
Old Jan 24, 2009 | 08:35 PM
Gear Poet's Avatar
With both windows rolled down, take a 90 degree corner at a slightly higher than normal speed. If you have a bad u-joint, chances are you'll hear it.
You should hope it's a bad u-joint. If you've got a bad vibration in the stick of your NV5600, it could be something worse.
Old Jan 25, 2009 | 12:04 AM
nickg's Avatar
crap I forgot the rust around seals symptom!! good catch
EverydayDiesel
41
Jan 17, 2008 11:49 PM
rjm022
Apr 18, 2007 09:44 PM
Mark Hodowanec
Sep 21, 2006 03:40 PM
dodgediesel4x4
Apr 13, 2004 06:32 PM
