Wheel speed sensor bracket
Well I got my front brakes done today, new rotors, calipers, pads, and brake hoses, for $904. As I pulled back into my driveway, the ABS light and brake light came on. On the passenger side, the wire or little hose for the wheel speed sensor was in direct contact with the rotor, which had burned most of the way through it. On the driver's side, there is a metal bracket which holds this wire up and out of the way, the bracket is missing on the pass. side.
The shop is gonna try to order one for me and fix it.
Anyone know if this bracket is available, or is it something you have to pull off a junker? Wonder if mine is still sitting in their shop. What a PIA. Anyone had that happen? On the plus side, my brakes work fine, just no ABS, which is fine with me. Gotta get it fixed before DOT gets me though.
The shop is gonna try to order one for me and fix it.Anyone know if this bracket is available, or is it something you have to pull off a junker? Wonder if mine is still sitting in their shop. What a PIA. Anyone had that happen? On the plus side, my brakes work fine, just no ABS, which is fine with me. Gotta get it fixed before DOT gets me though.
dover
Oct 7, 2007 08:48 PM
