wheel hubs
Old Apr 11, 2007 | 05:53 PM
YZ3500F's Avatar
wheel hubs
Hi this is my first time on this forum so bear with me i have a 2002 3/4 ton long boxs cummins with 87,000 miles and i just had my left front hub go out while driving home i was able to nurse it to the shop and there gona fix it for 500 dollers. Im just wonderin if other people have exsprice this problem.
Old Apr 11, 2007 | 08:34 PM
matthopp's Avatar
Assuming 2WD, first hub when out at about 75K, the other went out at about 88K. Dealer only part, $275. First change was about two hours (spindle nut was very difficult to get off) and the second i did in less than an hour. I have not discovered a way to rebuild my old ones with a new timken bearing.
Old Apr 11, 2007 | 10:29 PM
johnh's Avatar
i posted this several years ago, here it again......
here`s a new twist on the sealed wheel bearings on my 01 3500 .... (rwd) I noticed a strange noise when turning left, the noise would go away when I applied my brakes. so I figured it`s time to replace at least the front pads. but when I jacked it up , I found a real loose wheel bearing ... fearing the bearing had gone out, I proceeded to dismantle it (drivers side) Imagine my surprise when I started to remove the bearing nut and found it loose !!! apparently the rotation of the forward motion had loosend the self locking nut.... If I had not caught it early on, It could have caused some real damage..... So here`s a word of caution to any body that has a rwd dodge with sealed front wheel bearings------check dhe drivers side nut. the self locking feature on mine failed ----- mileage is about 113K
__________________
01 3500 ho ;4 inch exhaust bully dog stage 3 inj edge comp(removed hybrid hx 35/40 8/25/04) dyno 419.2 hp 891.8.torque w/stage 2`s on a dyno jet 6/25/03 ,htb2 turbo installed 8/25/04, not a dually any more,conversion done in 04
Old Jun 13, 2007 | 10:24 PM
jethroish's Avatar
I'm getting ready to change my front, drivers side hub. Kept hearing rattle at low speed, window down, hitting little bumps. Sounded just like a loose brake pad in the caliper. Hub bolt was loose by 1/2 turn and hub was slightly wobbling. Now with the bolt tight, there is a very slight rattle, but any rattle has to go. Truck has 112000 miles on it. Great timing too. Leaving tomorrow for a 1200 mile trip. Taking tools and jack with me. Yes, I have a 3/4 drive metric set, 19mm to 50mm.
Does the caliper mounting bracket HAVE to come off to change the hub?
If I remeber right, those bolts are 18mm. I have tried to break them loose in the past to absolutely no avail. Looking at the repair man., I am going to have to get them loose.
Old Sep 13, 2007 | 10:22 PM
emailrick1's Avatar
I am needing to change my hub bearing on my 2000 3500 dually 2x4..... where can I find the parts other than a dealer????????? any help? please email me also... at emailrick1@yahoo.com
Rick
Old Sep 14, 2007 | 07:46 AM
Mike D's Avatar
Napa Auto Part has them. They are Chicago Rawhide which is now owned by SKF.
Old Sep 14, 2007 | 10:46 AM
RowJ's Avatar
My 2002 lost drivers side at 100,000 miles. replaced both for just over 500.00 (parts). Bgt from NAPA.
RJ
Old Sep 18, 2007 | 08:57 PM
emailrick1's Avatar
Found one... $208 shipped to my door.... Dodge dealer that sells on EBAY.... I called my local dealer, same part # and Jobber cost was $260 + tax..... now to hope I change the correct one......
Rick
91oldranchtruck
Jan 31, 2011 09:45 AM
sherpadad
Jun 13, 2008 11:27 PM
LJRoy
May 13, 2008 05:36 PM
Adam F
Oct 26, 2006 08:01 PM
keffa11
Mar 10, 2004 11:56 PM
