What do these mean?
Old Apr 7, 2005 | 09:19 PM
Wolff's Avatar
What do these mean?
For some reason I decided to check and see if there were any codes on my truck so I did the process to check them and came up with
P0500 & P1693
My truck is stock other than bhaf and straight pipe
What do these mean exactly and how do I clear them?
Old Apr 7, 2005 | 09:30 PM
crobtex's Avatar
Look here: https://www.dieseltruckresource.com/...n&onlynewfaq=1
I don't know about the 1693.
Usually, disconnecting the battery for awhile will reset them. Also, around here, AutoZone will read and clear the code for you.
Old Apr 7, 2005 | 09:57 PM
dieselrob's Avatar
1693 is a companion code just saying you have a code with a prob.
Do you have a problems happening. I had the speed sensor prob and my abs light and parkin brake light was on in the dash and my speedo wouldnt work till 30 mph.
Its a little screw in s on the top of your pumpkin in the back you can get one at the dealer and it take 5 minutes tyo change, pop off wire take out 2 or3 bolts and unscrew it.
Old Apr 7, 2005 | 09:58 PM
phox_mulder's Avatar
1693 is the code telling you there is a code.
0500 is the speed sensor.
If your speedometer and odometer are working, you most likely spun your tires and haven't started/stopped the truck the required number of times to clear the code.
phox
Old Apr 8, 2005 | 07:52 AM
Mopar1973man's Avatar
Re: What do these mean?
P0500 & P1693
Those code are cause also by roll starting the engine. Mine has got the same two from doing this...
Old Apr 8, 2005 | 07:10 PM
johnh's Avatar
0500
as far as i know you can get rid of the 0500 code by disconnecting your batteries,but why bother? i can set a 0500 code just by revving the engine to any thing over an idle( for faster warmup ) i now have 0500,1693 codes
powerstrokin03
Dec 6, 2005 08:11 AM
benny
Oct 16, 2005 01:39 PM
boughtadodge
Jul 7, 2005 11:34 PM
cumminsman02
Apr 29, 2005 09:02 PM
Farmall
Feb 3, 2003 09:07 AM
