Water pump... "gasket" or "o-ring"??
Old Mar 26, 2008 | 08:02 AM
Invader's Avatar
Getting ready to do my pump today, and the seal that came with it is a square cross section solid ring.
Per the instructions, it says to use tacker if it's a gasket, or lubricant if it's an o ring.
It's really neither. Should I use nothing?
Thanks.
Old Mar 26, 2008 | 12:06 PM
rollincoal02's Avatar
i didnt use anything on mine when i replaced the pump. A little dab of grease maybe to hold the ring in the groove on the pump while you are getting it in place and starting the bolts
Old Mar 26, 2008 | 01:37 PM
Invader's Avatar
Used a bit of tack to get it in just right, thanks.
Now I have a bubble.
Which screw/plug should I remove to fill it up with?
Old Mar 26, 2008 | 03:15 PM
Mike D's Avatar
You have a bubble?
Old Mar 26, 2008 | 03:24 PM
Invader's Avatar
bubble = pocket of air in the cooling system.
Old Mar 26, 2008 | 06:36 PM
Fishin2Deep4U's Avatar
When the motor heats and then cools, it will pull coolant from the overflow and completely fill the engine.
Dave
Old Mar 26, 2008 | 07:06 PM
Invader's Avatar
It ended up being about a 1.5 gallon sized bubble after I vented the upper passages.
wheelieking71
Mar 8, 2011 03:58 PM
Hercules
Nov 8, 2009 08:27 PM
powermad
Jun 18, 2009 11:26 PM
wildchild97
Sep 25, 2007 02:44 PM
HaulinBut
May 12, 2006 03:06 PM
