VP44 Pump Failure??
Old Mar 23, 2004 | 09:42 PM
bryans250r's Avatar
VP44 Pump Failure??
I know this has been brought up many times but I've searched the board and haven't found the answer. I'll be quick about it here.
I know that my lift pump failed about 5 months ago. At the time I was told by a friend that I shouldn't worry about it until the engine has a hard time starting, so I didn't replace it. I now read on the board that my pump might be / is now compromised.
I very seldom tow with the vehicle (typically under 2000lbs total trailer weight) but noticed a power drop last time I pulled. From what I read my pump is toast but everything seems to be running fine. No rough idle, no lack of power (when unloaded), etc. I read that the VP44 has an internal lift pump that can supply the main pump at light loads. Could this have saved it or am I sitting on a time bomb?
How can I check my VP44 to understand if it is working properly? Any help is much appreciated. Thanks
Bryan
Old Mar 23, 2004 | 09:50 PM
BigBlue's Avatar
Go to your local dodge dealer. They have some sort of device that can check if the pump is working right or not.
IPDiesel
Jul 29, 2015 09:57 PM
dodgetrucker75
Mar 17, 2011 09:15 PM
hhrumph
Oct 4, 2010 02:48 AM
Haulin_in_Dixie
45
Mar 6, 2004 09:17 PM
